LA CITY FIRE STRS SYSTEM
patin
carson,california
LAFD STRS anyone monitor this system to confirm its use​
DEC HEX Mode Alpha TagDescriptionTag
130082D1 CENTRALCh 1 - OCB Operations Central BureauFire-Tac
131083D2 SOUTHCh 2 - OSB Operations South BureauFire-Tac
132084D3 VALLEYCh 3 - OVB Operations Valley BureauFire-Tac
133085D4 WESTCh 4 - OWB Operations West BureauFire-Tac
134086D5 BATT 1Ch 5 - Battalion 1Fire-Tac
135087D6 BATT 2Ch 6 - Battalion 2Fire-Tac
136088D7 BATT 4Ch 7 - Battalion 4Fire-Tac
137089D8 BATT 5Ch 8 - Battalion 5Fire-Tac
13808aD9 BATT 6Ch 9 - Battalion 6Fire-Tac
13908bD10 BATT 9Ch 10 - Battalion 9Fire-Tac
14008cD11 BATT 10Ch 11 - Battalion 10Fire-Tac
14108dD12 BATT 11Ch 12 - Battalion 11Fire-Tac
14208eD13 BATT 12Ch 13 - Battalion 12Fire-Tac
14308fD14 BATT 13Ch 14 - Battalion 13Fire-Tac
144090D15 BATT 14Ch 15 - Battalion 14Fire-Tac
145091D16 BATT 15Ch 16 - Battalion 15Fire-Tac
146092D17 BATT 17Ch 17 - Battalion 17Fire-Tac
147093D18 BATT 18Ch18 - Battalion 18Fire-Tac
148094D19 LAX ARFFCh 19 - LAX ARFFFire-Tac
149095D20 VNY ARFFCh 20 - Van Nuys ARFFFire-Tac
150096D21 PT FERMINCh 21 - Pt Fermin Marine OpsFire-Tac
151097D22 FCDSSCh 22 - Fire Communications Dispatch Support SectionFire-Tac
152098DE23 METROCh 23 - MFC Metropolitan Fire CommunicationsFire-Tac
153099D24 FPB 1Ch 24 - Fire Prevention Bureau 1Fire-Tac
15409aD25 FPB 2Ch 25 - Fire Prevention Bureau 2Fire-Tac
15509bD26 ISTS 1Ch 26 - In Service Training Section 1Fire-Tac
15609cD27 ISTS 2Ch 27 - In Service Training Section 2Fire-Tac
15709dDE28 ARSONCh 28 - ArsonFire-Tac
15809eDE29 TEMSCh 29 - Tactical Emergency Medical SupportFire-Tac
15909fDE30 JHATCh 30 - Joint Hazard Assessment TeamFire-Tac
1600a0D31 AIR OPSCh 31 - Air OperationsFire-Tac
1610a1D32 USAR DPSCh 32 - Urban Search And RescueFire-Tac
1620a2D33 FIMT TACCh 33 - Field Incident Management TeamFire-Tac
1630a3D34 EVENT 1Ch 34 - Event 1Fire-Tac
1640a4D35 EVENT 2Ch 35 - Event 2Fire-Tac
1650a5D36 EVENT 3Ch 36 - Event 3Fire-Tac
1660a6D37 EVENT 4Ch 37 - Event 4Fire-Tac
1670a7D38 EVENT 5Ch 35 - Event 5Fire-Tac
1680a8D39 EVENT 6Ch 39 - Event 6Fire-Tac
1690a9D40 LOGISTICSCh 40 - Logistics
LAflyer
Global DB Admin
Moderator
SoCal
Yes it does have activity. Air Ops, fire prevention, arson and event TGs tend to be the most frequent users.
Additionally, the battalion and bureau TGs have random chit-chat, usually around larger incidents when the 800Mhz analog channels might be tied up.
es93546
A Member Twice
Right Side of CA on maps
DECHEXModeAlpha TagDescriptionTag
Are the talkgroups assigned to battalions actually tac channels? I suppose Event talkgroups could be used as tacticals, but Event frequencies and talkgroups are generally used for large preplanned events, such as marathons and similar.
Los Angeles County / Marin County, CA
The TGs assigned to battalions are mainly used for earthquake mode, tsunami mode, or other department wide, battalion wide, or bureau wide events that require non emergency coordination. All channels on the STRS system are not authorized to be used on incidents where members will be in an area of immediate danger to life and health (IDLH) because of the risk of not being able to transmit or send a mayday.
When earthquakes occur in the city, you will normally hear all companies in all battalions check in with their BCs via the talk group.
The event TGs are used for preplanned events.
Arson, TEMS, JHAT, Command, and Metro TGs are/will almost always be encrypted.
Airops TG is normally the most active and is always monitored by airops. I've heard it used between the aeromedic and the hoist ship on hiker incidents.
Engine104
Member since 2005
Winnetka, CA
I was looking at the coverage maps in the RRDB and the two sites listed seem to be aimed more at metro-L.A, rather than the SFV. There looks like there is a site on Oat and on Mt. Lukens. Are those used, and are they simulcast? Just wondering about reception in the West SFV.Thanks.
I'm not sure about what site specifically gets used but I do know that it's receivable across the city boundaries. STRS is used by many other city departments and would likely go through Oat mtn for the valley tgs.
LAflyer
Global DB Admin
Moderator
SoCal
STRS is a very busy system hosting many LA City agencies - DOT, Public Works, Sanitation, Parks, and even the LAPD.
Both sites are simulcast. Not all TGs are on both sites. For example, if memory serves me right, most(all?) DOT activity is on Site 1..
