Does anyone happen to know what the LC fire net is for Tac 2? I looked in Database and couldn't find it.
Which is it? TAC 2 or MA 2? What did you seen?Or it could be LC MA 2
| 9167 | 23cf | D | LarimerCo SAR | Search & Rescue |
| 154.385 | WQFI850 | B | 156.7 PL | Larimer SO 4 FN | Sheriff 4 Fire Net |
Often times if you are listening to LC Fire on DTRS, you are hearing some of the volunteer fire depts communicating with LC dispatch/LC emergency services, then they have their own fireground channel(s). For example it is very common to hear Rist Canyon VFD operating on LC Fire and then they will 'switch to tac 2' and go to their own vhf fireground channel, in their case it is 156.000, which you can pick up in ft collins/loveland provided they aren't far up beyond the hills. Dunno if that helps, but it sounds like what you heard.Thank you KEOHIN, and your right I think tac 2 is 9167. They were on a rescue when they said go to Tac-2 first they were on fire net 154.385
Does anyone know if Rist Canyon uses APX 7/8000s? Or do they have separate VHF radios?Often times if you are listening to LC Fire on DTRS, you are hearing some of the volunteer fire depts communicating with LC dispatch/LC emergency services, then they have their own fireground channel(s). For example it is very common to hear Rist Canyon VFD operating on LC Fire and then they will 'switch to tac 2' and go to their own vhf fireground channel, in their case it is 156.000, which you can pick up in ft collins/loveland provided they aren't far up beyond the hills. Dunno if that helps, but it sounds like what you heard.
I believe (but not totally sure, it's been years) the old vfh firenet is still up, used by LCSO when they're in a dtrs dead spot and need to get out
