Larsen Tri-band (800) vs 150/450 dual-band
redhatnick
Charlotte, NC
I live in North Carolina which has an 800mhz statewide trunked radio system (VIPER), but frequently tip-toe across into Virginia which uses a 150mhz statewide trunked radio system (STARS). While the Larsen tri-band seems to pickup the 800mhz networks well, I'm considering making an investment in a dedicated 150/450 antenna. If I'm understanding antenna theory correctly, lower bands require taller antennas and higher bands can use shorter antennas.
The Larsen Tri-band (150/450/800) height (16.5') seems to indicate a sweet spot in the 800mhz range, but reduced performance further down in the 150mhz band which makes it a poor performer in some of the more remote areas in VA where the sites are further apart.
I'm considering ordering a Laird Tech CB150/450CS - $69.95 : The Antenna Farm :: , Your Two Way Radio Source! Laird CB150/450CS (height 36') to remedy the Larsen's performance in the low band but I have a few questions.
1) Even though the Laird CB150/450CS is twice as tall than the Larsen Tri-band, how well would the CB150/450 would perform back in the 800mhz band? It would be quite oversize for a 800mhz antenna, but does this reduce performance? Would this be better, worst, or equal to an ordinary antenna in the 800mhz-only band?
2) Is my perception of performance on the Larsen on 150mhz just in my head? If not, how have others remedied the low-band performance or have they just accepted it?
3) When waiting for friends and family at the airport, I also would like to tune into air traffic control (118-136mhz). While not in either's recommended band, would the CB150/450CS improve reception compared to the Larsen Tri-band, or would it be no improvement here?
An antenna specifically designed and tuned for a specific frequency will just about always outperform a random length antenna.
16.5" is not a sweet spot for 800, it's closer to a VHF sweet spot. The design of the antenna helps it perform well across several bands, but the antenna design doesn't provide a lot of gain.
What I'd suggest is to use the 150/450 antenna for your VHF and UHF scanning. Get a dedicated 800MHz antenna that has some gain and use that as your second antenna. This would likely give you the better performance.
The 150/450 antenna will work on VHF Low also, as the 5/8's design of the VHF portion of that antenna will be close to 1/4 wave on VHF Low.
Also, for scanning, don't get to hung up on the frequencies listed for the antennas. True, an antenna specifically tuned for a frequency will work better, however you have plenty of bandwidth to play with. The 150/450 antenna will work well on the VHF High band and the UHF band quite well. It'll also work just fine on the VHF Air Band.
n4yek
Cosby, Tennessee
I live in Cosby Tn and am over 50+ miles away from the nearest Virginia STARS repeater. I can monitor it from my car with the Larsen Tri-band antenna easily. Don't sell it short, it does a great job.
Rt169Radio
CT
If you want to listen to 800 MHz a lot get a dedicated antenna for that and keep the Larsen tri-band antenna for the 150/450 MHz stuff.
