maxkluge
Can anyone point me toward Icom software for the PCR-100 that is later than revision 1.0?
Thanks in advance!
Thanks in advance!
maxkluge said:Can anyone point me toward Icom software for the PCR-100 that is later than revision 1.0?
Thanks in advance!
maxkluge said:1.0 just seems to work strange, (might have been long data cable) from screen to screen, how can I get some newer stuff, E-mail? buy it from Icom?
Someone said that if you use the rxbase.dll file from the PCR1000 software with the PCR100, that it would then run under XP. give that a try.
kmacka said:Great Lakes, Do you use a serial to usb adapter, if so which one.
This is the one that would work of most software for me..GreatLakes said:No, I'm running serial cables on all my radios at the moment. As maxkluge said, there was someone on RR claiming to be using a USB-to-serial adapter cable successfully. Check out blueline_308's comments in this thread:
http://www.radioreference.com/forums/showthread.php?t=63465
rlb said:This is the one that would work of most software for me..
http://www.sfcable.com/cable/p/D920-06.html
