Latest PPS with Windows 11 Snapdragon X Elite connection issue
Medic_330
Trying to program my Unication G5 pager with my Dell XPS computer. Is there a known issue with the PPS and Snapdragon X Elite processor? My pager makes the connection sound and charges when I plug it in but it won’t connect to the PPS. Tried downloading the drivers and still the same issue. Looked at the USB and serial settings under the Device Manager and all show connected with no errors. I’m now using a cheap Lenovo with an Intel i5 processor with no issues. Just curious if anyone else is having issues with these new Snapdragon PC’s.
@Medic_330 this has been asked and answered several times, check out these posts and let us know if you are still having trouble.
N6ML
Has it, though? The question is specifically about that particular processor, which is ARM based. I wouldn't assume that the Unication-provided driver would support that, but I don't know.....
amickey1979
Easton, MD
Has anyone figured out how to use the PPS with a Snapdragon Processor? I have a new Surface Laptop and I have tried everything to include installing the drivers and it's a no go so far.
Kiniutech
Past login as: questnz
Somwhere in the South Pacific
With introduction of Apple M (ARM) and Qualcom Cpu's and ARM Windows it is a high time to ask Radio software developers to come forward and list supported CPU's and models their software run on in native mode. Or specified otherwise way around limitations.
Many run only on Intel CPU's.
Hit_Factor
Saint Joseph, MI
.... Just curious if anyone else is having issues with these new Snapdragon PC’s.
Yes, similar to the folks with Mac computers. People are clamoring for compatibility. Apps like Google drive and Adobe InDesign and Illustrator are not (or were not initially) supported. My guess is arm for windows will be supported and the Mac users will keep asking for support.
My guess is this lack of compatibility is why surface laptops are discounted several hundred dollars at sites like Costco.
K9KLC
Southwest, IL
Unfortunately, you're probably correct about the Mac part. And at the rate I keep having problems with Windows every update (well or many of them) it gets old.
rolesnevich
Butler County, PA
Correction on intel only but X86 and x64 which is intel and AMD
rolesnevich
Butler County, PA
Not really Apple intel application general work on Apple Silicon. Because Apple created a very good translation layer to transtale the X64 commands to Apple Silicon commands. The issue with PPS, the need drivers that only work with x64 and x32. At some point I might play and see if can gett it working on crossover on my m4 mac but since it works fine on my desktop with amd it not high pressing need
David_Oney
Former Unication Tech Support
Unication Representative
Raceland, KY
Did you go into features and enable .NET framework 3.5? I'm not sure they ever updated the software to use the new framework. When you connect the unit what does the Device manager say? The unit should show up under Network adapters.
estone4009
Philpot, KY
Yes, I have enabled .NET framework 3.5. The device shows up under ports as COM port 8 and not as a netowrk adapter. I alerted support to what I was seeing and didn't really get any indication that it was something they had plans to fix. Was hoping somone else had found a work around.
David_Oney
Raceland, KY
It should show up as Unication USB Ethernet/RNDIS in device manager under Network adapters. I hope you find a resolution.
Medic_330
Still no luck with Unication. My DMR 6X2 Pro from BTECH now works with my Snapdragon PC so hopefully soon enough Unication will update their drivers.
estone4009
Philpot, KY
I would be happy if support acknowleged the issue and actually said they were working on a fix. At this point I am not even sure they have committed to fixing the problem based on responses I have gotten from support.
