Lee County NC Going to VIPER
DavidQ
Sanford, NC
Thanks. Still trying to figure out P25 system. Based on info I have been researching my BCD996P2 can use just the control channels to monitor this system. I had all frequencies listed on the tower site programmed. I see if it makes a difference. Still getting hit/miss reception.
GMB2711
Spring Lake, NC
Well i monitored Lee Co testing their (EMS/FIRE) on vhf all day today and they are now back on vhf, however Sheriff still on viper. they were on viper for a couple weeks before switching back, so don't know what is going on with that, but will keep monitoring for any other changes
Chris0516
Pittsboro, North Carolina
So, Does that mean? I should keep both, analog, and digital, systems in the scanner? In case they flip-flop, again? I thought they had come to the conclusion that a digital system would improve radio communications?
I couldn't find the original article from last year announcing the move to digital. The report recommending the move to digital, improving response times. Was done by a retired Fire Chief.
Chris-KH2PM
Northern Harnett Co. NC
While monitoring the Tramway tower, I'm seeing TG 27011 Lee County SO CID is ENC with AES-256.
For now Lee Co SO is in the clear.
Submitted to the DB admins.
GMB2711
Spring Lake, NC
I would keep both yes because of simulcast they have done this before with (DMR) and then back to VHF/UHF so we will see viper would be their best bet, but Mabe it a tower problem not enough of them
tvengr
Well Known Member
Baltimore County, MD
Which sites are you scanning and what programming software are you using?
DavidQ
Sanford, NC
I am scanning Broadway & Tramway towers. I consistently hear Fire Dispatch TGID off the Broadway tower. Have also heard City Tac 1, Lemon Springs Tac, and Northview Tac TGID’s but it has been inconsistent with receiving the Tac channels. Have 5 bars signal strength with Broadway and 3 with Tramway. Only using stock antenna. Ordered a 700-900mhz antenna. Will see if that helps.
Boonetrail12
Many of the Lee Co SO TGs have been in the database since last October...
270096981DLEESOLee County SheriffLaw DispatchLee County2014-10-25
270106982DLEESOADMINLee County Sheriff AdminLaw TalkLee County2014-10-25
270116983DLEESOCIDLee County Sheriff CIDLaw TacLee County2014-10-25
270126984DLEESONARCLee County Sheriff NARCLaw TacLee County2014-10-25
270136985DLEESOOPSLee County Sheriff OPSLaw TacLee County2014-10-25
270146986DLEETACLee County TACMulti-TacLee County2014-10-25
270156987DLEETAC2Lee County TAC 2Multi-TacLee County2014-10-25
270166988DLEETAC3Lee County TAC 3Multi-TacLee County2014-10-25
270176989DLEETAC4Lee County TAC 4Multi-TacLee County2014-10-25
27018698aDLEETAC5Lee County TAC 5Multi-TacLee County2014-10-25
27019698bDLEETAC6Lee County TAC 6Multi-TacLee County2014-10-25
27020698cDLEETAC7Lee County TAC 7Multi-TacLee County2014-10-25
27021698dDLEETAC8Lee County TAC 8Multi-TacLee County2014-10-25
Any where to find the updated TGs at?
Until someone discovers them using search on the scanner or SDR, identifies the usage and submits them to the database, NO. That is not publicly available information from the county.
DavidQ
Sanford, NC
These are channels I have heard so far:
TGID's
27007 - "Fire Dispatch"
27014 - "City Tac 1" (Sanford Fire) City Fire has 2 Tac channels. Don't know TGID for "City Tac 2" yet
27018- "Cape Fear Tac" (Lee Co. Tac 5)
27019- "Northview Tac" (Lee Co. Tac 6)
27020- "Lemon Springs Tac" (Lee Co. Tac 7)
I believe the following department TGID's are as follows but I have not confirmed yet:
27015- "Tramway Tac" (Lee Co. Tac 2)
27017- "Deep River Tac" (Lee Co. Tac 4)
27021- "Carolina Trace Tac" (Lee Co. Tac 8)
Chris0516
This, 'VHF/UHF conventional. EMS and Fire are patched to the NXDN system... law enforcement may be as well, but this has not yet been confirmed. EMS has also been confirmed to be patched to VIPER', is what North Carolina VIPER Counties Verified says. I can't edit it, because. My RR Subscription lapsed. FD needs to be added to the last sentence.
IcomIcR20
You do not need a subscription to edit the Wiki.
Chris0516
Looking again at my log.
I have seen these on VIPER
27002-Lee County EMS
27007-Lee County FD
27009-Lee County Sheriffs Office
27014-Lee County TAC
27018-Lee County TAC 5
