Left handed mic use mobile?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Even though I am left handed, I only use my right hand with my mobiles. I do not have enough room to mount my radio on the left side of my truck. Having said that, if I had a right hand drive vehicle, I would likely use my left have for my radio.
Sent from my iPad using Tapatalk
jonwienke
More Info Coming Soon!
VA
The mic cord is generally not long enough to hold in the left hand in a vehicle.
12dbsinad
I was considering buying a right hand drive vehicle so I could hold the mic with my left hand, but decided against it :). I got used to using my right.
cmdrwill
So Cali
I remember one of my customers had me extend the mic cord, he mounted the mic on on the hang-up box which was mounted on the door of the truck. Does that qualify as a lefthanded mic? Sort of handy, just reach into the window to pick up the mic when working outside the truck.
Most all mobile installations have the mic so it is accessible from either seat, in the middle.
Delivers1234
Modesto, CA
I can extend the mic (I have a 7 ft cord). I'm running out of space in the middle and since I'm left handed I was thinking of the car door or the edge of the dash.
I also have 2mics ones from a yasesu and ones from a bearcat ssb cb.
Delta33
Clinton Iowa
Make more room in the Center, or Ditch the cb. Very simple solution. ;)
yaknamedjak
localhost
Seems to me like it'd be easy enough to run an extension under the steering column along the top of the driver footwell, even under the plastic fairing, and have it pop out over there, and stick a mic clip on the dash to the left the steering wheel, no?
jonwienke
VA
Just make sure your cable run can't get tangled in the gas/brake/clutch pedal mechanisms.
KK4JUG
GA
Yeah, right. That would be on top of my list of things to do when I get really, really bored.
Grondoline
This might work if you can still find one. The hang-up button is on the front side. They called it the "no juggle" mike.
