CycleSycho
While I was downloading/installing the new library, the internal PC card reader crapped. I was using an external card reader (because the internal one was under the desk in the PC) and all of a sudden the update failed. Upon retrying, the card was not recognized. I first had to remove the internal card reader since ALL the USB was not responding (and the PC went rrrreeeaaalll slow). Hard shutdown was the only fix to the slow PC, but every time I tried to get the SD card to 'listen' in the USB buss, it would not. The card formatted OK in 'SD card formatter' (quick and full) but whistler EZ-Scan would not 'Prepare card for use' because the 'format' would not happen within the program.
How do I load all the files if EZ-Scan will not let the card format? Does anyone have the standard filed the SD card needs,? I thought I had saved the files BUT upon opening the 'legacy' upgrade folder in my other drive, I realized I did not copy the SD card (like I did with the PRO-668, backed up many moons ago).
I would LIKE to see if the restoration of the files on the SD card will allow the scanner to work until I get a backup SD card (you know, get the firmware and such to see if the scanner will work with the card), but I am not sure it'll work. I did not have the scanner hooked up to the PC when this happened so I do not think the scanner got damaged when the buss went haywire.
Can anyone help me with the files, and the order I should follow to MAYBE get the scanner back up and running? If so, I would appreciate the help (and believe me, it'll really help). Thank you in advance, for any assistance possible.
George (CycleSycho)
George (CycleSycho)
