You could join the sds100 Facebook group but I suspect many of those users may be registered here also which would hamper results.
No, the cold solder joint issue. This and battery swelling is what’s stopping me from buying one. Went with the 325P2 for now.you talking about cracking? yeah, most of my factory Uniden antennas have cracked up plastic.
I've had 4 of the larger batteries from the very beginning (3 plus years of ownership of an SDS100) and I've never actually achieved 6.5 hours of runtime like so many have stated or claimed. HOWEVER, SDR's can't hide the reality that they're notorious battery hogs and I find it analogous to the fuel economy standard(s) of a Cadillac Eldorado with a 501 engine. Unless or until the next generation of somewhat compact batteries appear on the scene, there just aren't going to be many glowing reports of even reasonably long battery life to write home about. Regarding the rotary controller issue: structurally, the encoder on both the SDS 100 & 200 are total crap and considering just how much use they get, (as well as the price point of these two scanners) there's absolutely no excuse for not making this part or component as close to bombproof as is mechanically possible in this day and age. No, I don't expect commercial grade build quality in a consumer electronics device but again, why a bare minimum cannot be achieved on the part of Uniden defies any and all logic.Have the original small battery that came with my early production SDD100 and the free large battery provided by Uniden.
Shortly after purchasing my SDS100 bought the external charging cradle that came with one of the bigger cells.
To date, no issues (swelling etc.) detected.
I have the low voltage warning on my SDS100 set at 3.6V.
I won't mention the faulty rotary controller and broken battery clip that necessitated a return to Uniden for repair.
I agree, I have one and love it. Was a little peculiar in learning the workings of how to program it, but once I did, it was easy.The BCD325P2 is a great little scanner😁...
It's a quality issues at the manufacturing plant, or actually what Uniden have specified as adequate. And in later years Uniden have allowed lower quality hardware to be used in their scanners to cut costs. It's a balance between cost and the failure rate you can accept and the number of unhappy buyers you get. These are the cheapest cells Uniden use and have an expected life span of 2-3 years of normal use and up to 300-500 charge cycles that typically equals to 3 years for a normal user. My battery failed after 2 years and falls into that time frame.It seems most do not have the battery swelling issues. Need to pin point what’s causing this issue. Once identified, may buy one.
My original large battery is from 2018. Always on charge, no swelling.Never had a Uniden battery swell. But I don't leave mine plugged in. Once charged I remove from charge.
I HAVE had a number of jetpack lithium battery packs swell in units over the same period of time. Those cellular units are plugged in 27/4 and IMO why those units well. My Uniden would probably swell if I left it being charged 24/7. Plus, where it is left matters as to sunlight and temperature. These simplified results of this poll are not very relevant IMO.
