live feed
D16Hanson
Sheboygan
i was trying to find out what i have to set my radioshack pro 652 scanner to listen to the sheboygan county fire and ems feed.
fredva
Virginia/West Virginia
Based on the feed description, it appears to contain frequencies from Sheboygan County, Wisconsin (WI) Scanner Frequencies and Radio Frequency Reference and a trunking system documented on this page: Sheboygan County Trunking System, Various, Wisconsin - Scanner Frequencies. A trunking system is a combination of frequencies and talkgroups that are used for specific types of communication. Refer to your scanner's documentation on programming both conventional frequencies and trunking systems. A lot of people use software to program their scanners because it can be more convenient, but you can also do it manually.
Also, a "feed" usually refers to somebody broadcasting what is heard on his/her scanner over the internet for others to listen. If you are just wanting to listen to radio transmissions on your own scanner, that's not called a feed.
