LMRN set up with DSD+
jets1961
I am in for a visit to Ontario. I have the York (142.140) CC running in DSD+. I see the events log, but I don't see TG action channel activity screen. Is that because I don't have the channel frequencies in the frequency file?
Anyone have the full frequency fill they can share? Also I can see the all radio windows but not the TG window. Could this cause that, or is that a DSD+ thing?
jets1961
Thanks Forts worked like a charm, I can now see the Current Groups windows.
So does DSD+ still need the channel frequencies because it's VHF?
jets1961
No, the system will learn the bandplan and display the proper frequencies by itself.
So in my case it is not. Should the FMP24 BW be set to 12.5 for VHF? The DSD+ directory was a copy of a 700MHz system then I modified the .bat files. Maybe I have to deleted an already populated file. I'll go look now, but if you know, let me know.
gary123
here is a FMP24 for a LMRN site. just change the frequency.
FMP24 -o7654 -f142.590 -b12.5 -g44.3
The gain can be tweaked for your local tower. FYI dont forget to set up the DSD.bat to the same port. In this example It is 7654.
Once you get it going the P25Data, radios and groups will populate. LMRN is suing OTA so you will also start seeing the radio aliases. EMS is good as it shows the actual unit number. OPP just shows the RID with no alias.
