LMRN Technical Data Discussion
west-pac
Can someone help identify what I'm seeing on DSD+? I'm in central Indiana, USA, and I believe I'm receiving a site from the FleetNet Ontario Gov't Zone 1 system; but it's P25, not Motorola type II.
The info I have:
WACN: BEE00
System: AD9
Site: 1.17
NAC: AD7
CC: 142.665
ACC/SCC: 142.185
ACC/SCC: 142.500
ACC/SCC: 142.905
Neighbor: 1.16 CC: 142.320
Neighbor: 1.20 CC: 142.260
The TGs I've seen are 517, and 520.
I searched for the AD9 system, but came up with no results. Are these 4 Ontario zones switching to P25? The CC frequencies I received match the CC frequencies for the Zone 1 Motorola system for sites 16, 17, and 20.
ve3ext
The info I have:
WACN: BEE00
System: AD9
Site: 1.17
NAC: AD7
CC: 142.665
ACC/SCC: 142.185
ACC/SCC: 142.500
ACC/SCC: 142.905
I believe you are hearing the beginnings of a new P25 Ontariowide system to be used by all provincial agencies. Supposed to be fully encrypted.
I have recorded these control channels here in the Windsor Essex county area. The test bed for the new system.
I imagine a new thread will start to follow development of this system
Jerry VE3EXT
west-pac
I have recorded these control channels here in the Windsor Essex county area, the test bed for the new system.
Jerry VE3EXT
Both of those TGs (517 and 520) were encrypted.
Enjoi19
Ontario, Canada
I started searching the TAFL... and someone feel free to correct me if I'm barking up the wrong trees here...
Punched in the control channel frequency found here. Came up with a listing that's active as of Oct 1st this year for Essex.
I see what looks like another site called Trafalgar that is licensed to be active the same day in a similar VHF range. Location is around the 401 / Sixth Line MTO station. I copied down the frequencies here if anyone in the area wants to try and see what comes up. Some do match fleetnet frequencies as shown above.
138.3450
138.6450
138.7350
138.9750
139.0500
142.1850
142.3650
142.6650
142.7550
142.9950
143.0700
Here's the account on the TAFL: TAFL Search Results
If I'm fully barking up the wrong tree on my data search here, let me know.
ATCTech
What's the Trafalgar frequency?
EDIT: Disregard - I see the list on the TAFL. There's no tower at that weigh scale however there is a Bell Mobility tower on the east side of 6th Line right next to it.
Enjoi19
Ontario, Canada
In my continued browsing of the TAFL for LMRN, I see what looks like like a vehicle repeater system too? But it's in the 700 and 800 MHz range. Reference identifier comes up with FDVR Repeater in all of them.
ATCTech
That's interesting. There was a TAFL update about 4 years ago that contained three 770 MHz band frequencies named "Bell Mobility Radio P25 Test" with the corresponding +30 MHz input frequencies as well. They disappeared in the next update. There was also a single 143 MHz P25 license for the Bell Mobility tower at 407 & 6th Line in Oakville which did in fact transmit a P25/P2 signal for a few weeks back then, silent since.
mikewazowski
Forums Manager
Oot and Aboot
FDVR would probably be a Fixed Digital Voice Repeater. Judging by the locations, I’m guessing it’s kind of like a BEAT repeater replacement.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
west-pac
Just looking at the distance for this capture. Around 200 miles or 350 kilometres. Thanks for reporting this.
Since the system is live and testing, we might as well let the games begin.
Thank you. I measured it with Google Maps and it was around 175 miles line-of-sight from Windsor to my location. That's still a good distance. I believe my location is around 900 ft ASL, and my antenna is 25 ft AGL. I'm using a Comet CX-333 antenna.
There were a couple other voices channels I found in that 142.500-143.000Mhz range, the NACs were 2D1, and A1E, but I'm not sure if they are part of this system or not. The A1E NAC was associated with TG:1 with DES-OCF(?) encryption. Again, I'm not sure if these are associated with the Canadian system.
Forts
Mentor
Ontario, Canada
I'd imagine they will use a DVRS for the repeaters. Fully digital and supports encryption. Who knows which band though...
Back in the late summer we were seeing weird patches on the current system to 10xxx talkgroups. I'm wondering now if those were patches into the new system. From the sites that are now testing it looks like the new control channel can be found on the current sites alernate CC frequency.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
How are you seeing this information such as the talkgroups if it's encrypted? Or is this just found via an SDR application?
The original poster from Indiana saw this information via DSD+ software. Others in southwestern Ontario were also watching but did not come forward until this thread came up.
The P25 talkgroups are relative to the Motorola talkgroups by being divisible by 16. They were correlated that way.
Muxlow
Super Secret
Middlesex County
Keep in mind the 700 MHz band used 6.25 kHz spacing so that's 771.88125 MHz to be deadly accurate. Site inputs are +30 MHz up there which would be 801.88125 in this case.
771.8813 / 801.8813 is right off their radio license. Listed as a FDVR. In service date of 2020-10-01
Muxlow
Super Secret
Middlesex County
Radio testing today off Site 16 Chatham
TG 5 and TG 6 (BMR talkgroups)
Both groups were using Phase 2
Radio ID's of
15006
100084
790056
