APX Looking for some codeplugs
dmason04
I support our police.
BEE00-152-1-5
Howdy y'all,
I'm looking for a codeplug for an APX 900, blank or used for programming. I'm also curious to see how one goes about programming a GTR 8000 trunking repeater and what CPS version I need to accomplish that.
Thanks,
David
tyler3328
You would need your specific feature set/model to have a codeplug that you can edit and not have any errors when transferring/cloning to another device. They aren't plug and play like ham devices. Easiest way is to read the radio you have. As for the GTR you would have to purchase the software from Motorola and download it from MyView portal. If you aren't familiar with programming them I would not recommend just trying things or you run the chance of seriously screwing up the system and preventing authorized users from accessing sites. Not to mention the other hardware requirements that are needed for a TRS site.
NVAGVUP
GTR doesn't use CPS, it uses CSS (configuration service software) and is usually SWDL'ed over the RNI.
If you don't know MTS2000's acronyms, you should not touch a GTR8000. This is deep water and you are more likely to go backwards if you don't know what you are doing before you connect. (Unless the significant risk of impairing the repeater is not an issue)
dmason04
BEE00-152-1-5
I'm just working on learning the software, I don't actually have an APX 900. Any feature set would work, I was just trying to see if I could find a codeplug. Same goes for the GTR 8000.
