Looking for the elusive hkn6155 programming cable
thecircusbear
Ok so, I’ve done a lot of research. I have a high power W3 Astro spectra plus. Based on everything I’ve read I absolutely NEED the HKN6155 to program it. Can anyone verify that fact? There was some data about a db9 to db25 pinout for the high power AS+ but I doubt this will work for the w3. I’d be prepared to actually pay for the cable if anyone has it.
thecircusbear
thank you for that info. I’m hoping the db9-db25 option cable will work with the w3. If not I’ll dive into the mic jack cable option which is slightly more complicated.
thecircusbear
That should be what your looking for.
That’s the one. But unfortunately it’s a unicorn and has been for some time now. No one has it in stock. I’m hoping the db9-db25 plans referenced in the wiki link above will work with the w3. I should know in a couple days and will post with my findings. Hopefully I won’t have to do any work with the jumpers (some ASP’s had rs232 disabled)
thecircusbear
I have one of these I can get rid of but the cable insulation is dry rotting/coming apart in some places.
Ok I may actually take you up on that BUT I just posted a separate “help me” thread about a 01/90 issue and whether or not I’m using the correct y cable or hhch. *sigh* once I can get that sorted, and can verify the cable I made doesn’t work, I’ll absolutely buy it off you, or rent it from you…whichever you prefer
KX5MOT
Lincoln County, OK
Well just let me know, I don't need this cable. So I will sell it.
