Dual-brick XTL5000, O5 head
KED306
Syracuse, NY
Adding in my obligatory "monitoring for further" so I can figure this out too... also, I feel your pain with lockdown keys. Should be common practice for agencies/shops to break the key before declaring the equipment surplus.
knockoffham
Michigan, USA
I have working tools now to remove the ASK. Will probably be a little while though until I can set things up hardware wise. We are having a mini blizzard and I don't really like climbing around in the trunk of my car getting covered in snow, and don't really feel like assembling a whole dual remote O5 setup indoors either. Unfortunately it is seeming like it is not as easy as force-enabling the dual radio field in CPS. Upon uploading the codeplug to my 'primary' radio, and powering up the radio, it does not show an alias on the screen, or give me any indication of an error of a missing second radio. I will see if I can torture it into compliance in some way.
knockoffham
Michigan, USA
Weather is good and I will mess with it today. However, it is seeming like it will not work and I will probably hook up an O3 or W3 head to the second radio. Even though it seems like I can trick it in the software- the modified codeplug either doesn’t properly upload to the radio. Or if it is, the radio is just ignoring it.
knockoffham
Michigan, USA
Looks like they were planning it in 2006… I wonder if work on that started before they decided on making a dual band APX. 1735489755199.png
KG4INW
Midlothian, VA
Dual Control Head was a feature that was implemented. It allowed two heads to be connected to a single radio though (think front, rear), not two radios to one head. I don't recall the limitations but nowadays, APX mobiles can have have up to 4 heads simultaneously.
I don't have any guidance on your quest unfortunately. I believe others have tried in the past but without success. Seemed to stop when APX came out. Best of luck!
knockoffham
Michigan, USA
Final update I never gave a few months ago: I gave up. I could force check the dual radio box, but it would not work write and upon re-reading the radio the option was not set up. So I just settled for one O5 radio and one O3 radio.
