WS1098: Looking to find
I’m looking to replace my dad’s whistler ws1098 as it has stopped working. Any advice on easy to use and not break the bank options? He listens to it 24/7 at home but isn’t good anymore with tech. I am not good with it other than the noise being a constant back ground noise :) thanks for any advice
Check my listing in the classifieds
  • Like
Reactions: wtp
Thanks i was hoping i could find something a bit cheaper but will keep my eye on this one
tvengr
Well Known Member
Baltimore County, MD
The screen is black and no sound.
What are you using to power it? If an AC adapter, try using the DC cable in your vehicle. The AC adapter may be bad. Everything in the scanner is controlled by settings on the SD card. I have repaired other scanners which appeared to be totally dead by replacing the SD card.
Thanks for this advice I will change out the cord and card and see if I get anywhere. It’s used in the house not a vehicle but I’ll get a new cord :)
