Looking to set up a feed that will broadcast my FD and neighboring FD
KearnyFMBA
Kearny, NJ
Looking for suggestions on a cost efficient setup for the ability to broadcast on the internet two channels. What kind of computer is best? A PC I assume. Software? And a decent cheap scanner? We have a stable high speed internet that’s never used. Analog UHF transmission.
jeepsandradios
East of the Mississippi
I find an SDR and a small form factor PC works very well for one or 2 channels. You can grab them on amazon for around $120 with windows and grab a SDR or 2 for $35 each. Ive got 3 of the little Beelink windows 11 computers setup at remote locations with a single SDR for monitoring and they work very well. Jungle site lists them for $122 right now.
KearnyFMBA
Kearny, NJ
Thanks, now with an SDR that’s what connects to the scanner? Or does that work as a scanner. I am way out of the game here. I do know what kind of computers you are talking about.
NotATechGuy
NotAMember
Is each channel a dedicated stream? Do you care about channel 1 stepping on channel 2? If yes, you will want a dedicated radio for each channel. If you already have radios for each channel, you could use Rx out from a radio. Other solutions would be two scanners and a PC. The most cost effective solution is setting up an SDR solution if you do not have scanners or radios dedicated to the channels already. Trouble with the SDR solution is that it will take more technical aptitude to setup.
As for the PC side of things, if not using an SDR, get yourself some cheap USB sound cards (or similar device) for each stream. The goal being to have multiple line/mic inputs so each stream can have a dedicated audio channel unless you are running an SDR. If you use an SDR you do not need external sound cards. The computer doesn't need to be anything fancy if all it's doing is streaming audio, enough power to run the apps you intend to use to stream with and other management tools.
With all of that in mind, I suggest you choose an audio source first. Pick how to get that audio to the computer, whether it be SDR and the audio stream is handled by the computer or the audio stream is an external source and you need multiple sound cards. If you use a radio, you only need to worry about audio. If you use scanners, you could look into setting up a program to control and program the scanners in addition to Rx audio. Once you have your audio sources you need to pick a solution to stream the audio.
KearnyFMBA
Kearny, NJ
Thanks for the suggestions. We do not care so much about the stepping on. So one will be the primary and the second feed will be on scan. It sounds like a simple scanner/radio set on scan between the two frequencies connected to a sound card is easiest.
