'Fry' it? Not likely, unless it's one of those el-cheapo Chinese models (and with that kind of Hf coverage, it might well be), and even then, it's more likely overloading will be an issue (especially if the person is living on the East Coast, where BC stations tend to be stronger). If there's a gain control on the amp (there should be...) then that's really not a big deal
However, you're right about the radio - and the big push is in the field of Software Defined Radios or SDRs. This isn't the forum for it, so I will point you to our HF equipment and Software Defined Radios forums for more on this topic.
Back to antennas - loops are still your best friend, just not the expensive Wellbrooks. For example you can build a nice loop and switchbox for a heckuva lot less - if you have some soldering and small tool experience. It should work quite well on these portables - it did a fine job when I was using my RX320. I wouldn't say that it was the equal of any outdoor antenna - that would be foolish - but it did a darn good job for what it was. It's called the Carpet Loop, and the link is below. Highly recommended.
The Carpet Loop -- antenna special on hard-core-dx.com
and there are any number of loop plans on the Net. Mike
