I must admit to some surprise at hearing that serious consideration is being given to employing diversity antenna systems on portable scanner equipment as a possible solution to the simulcast reception issue.
Have we conclusively determined that the methodology employed by professional subscriber equipment to deal with simulcast interference is too impractical to implement in a $600 or less consumer scanner? I know of no current professional LMR portable gear that uses diversity antenna technology. I may be wrong but I am skeptical of that being the primary solution (diversity antenna systems).
There are many reasons that using a diversity antenna solution would be impractical in a portable and possibly even mobile environment. As UpMan stated, we are dealing with many wavelengths here - even if we limit the solutions to 150MHz and above that still means we are dealing with wavelengths that range from about 6.5 feet at 150MHz to about a foot at 960MHz. For a quarter wave element we are saying between 19.5 inches at 150MHz to about 3 inches at 960MHz, give or take. For a diversity antenna to work well and effectively it should contain two or more equally effective antennas for a given desired frequency range. At the 2.4GHz range of 802.11bgn wireless systems this is practical given that the antennas are small - less than 5 inches for a full wavelength and a tad over 1 inch for a quarter wavelength and electrically shortening them, if necessary, is far simpler and less inefficient than at much lower, sub-1GHz frequencies. To electrically shorten a 150MHz antenna to fit within a small handheld device would make it very inefficient and so poor a performer relative to even a basic stock "rubber ducky" that if it were employed as a "second" antenna in a diversity antenna system it would be nearly useless. Yes, at 700MHz and up you MIGHT be able to accommodate this solution to some reasonable degree of effectiveness in a handheld device but it would still not be ideal unless you literally had two or more actual identical tuned antennas sporting physically from the device - pretty ungainly for the average user to hold in a comfortable manner. At the higher frequencies, 700MHz and up, a less efficient built-in antenna might work as a second antenna in tandem with the primary attached whip or ducky but the discrepancy between the two would mean that the user would only benefit at higher signal levels - the diversity system would only really be effective based on the signal levels coming from the least efficient antenna.
For fixed use it is a reasonable solution though pricey if for no other reason than the cost of the extra antennas, feedlines, and switching gear. For mobile use - maybe with the same issues plus less physical space, etc. For a handheld, it's tough, at least for lower frequencies.
And the above isn't even considering the many other aspects of correctly and effectively using a diversity antenna system such as implementing the logic to differentiate between signal qualities at each antenna - signal level is relatively easy but better effectiveness, especially for digital LMR systems, might be to compare BER (bit error rate) and ISI (inter-symbol interference) between the two. And this would have to be done for multiple methods of digital modulation if you are dealing with multiple digital modes. All of the extra RF plumbing also adds loss and noise to the system and provides even more potential paths for interference such as spurious signal generation, intermodulation, etc., which are already serious issues in consumer scanner radios.
I think that actually giving serious consideration to using diversity antenna solutions as a means to deal with LMR simulcast distortion (for those systems that use simulcast methods) should only be a last resort when faced with, possibly, the following cases:
1) Any reception outside of the intended service area that the simulcast system is optimized for; and
2) If it is absolutely confirmed that using the same methodology, whatever it may be, as is used in the professional subscriber gear is simply too costly or otherwise impractical to implement in consumer $600 or less scanner gear (yes, this assumes that said gear is not using a diversity antenna system to deal with simulcast distortion - an assumption I think is a practical and likely valid one).
-Mike
