The spelling errors alone prove the article should be taken with a grain of salt.
The comm systems here in SoCal look a little something like this.
Los Angeles County...
Los Angeles County Fire Department: 154/470 MHz Analog/Conventional
Los Angeles County Sheriffs Department: 482-483 MHz Analog/Conventional
Los Angeles Fire Department: 800 MHz Analog/Conventional
Los Angeles Police Department: 484/506-507 MHz Digital/Conventional
Los Angeles County Police Department: 800 MHz Analog/Trunked
Verdugo Fire (ICIS): 470MHz Analog/Digital/Trunked/Conventional
Smaller Municipal Departments: 154-156/460-508 MHz
California Highway Patrol: 39/42 MHz Analog/Conventional
Outside Los Angeles County...
Orange County Fire Department: 800 MHz Analog/Digital
Orange County Sheriffs Department: 800 MHz Analog/Digital (Encrypted 24/7)
Ventura County: 154-156 MHz Analog/Conventional
San Bernardino County: 154/460/800 MHz Analog/Trunked
Riverside County 151-155/800 MHz Analog/Trunked
San Diego County: 151/800Mhz Analog/Trunked
As you can see there are literally hundreds of frequencies in play within the County of Los Angeles alone and that list hasnt even scratched the surface. The State of California has a mutual aid radio system in play and has for over 30 years using the CLEMARS and FIREMARS systems with frequencies covering 30-900 MHz. Pretty much all fire departments have the FIREMARS and/or State White freqs programmed in their radios and the same goes for the police agencies with CLEMARS. There is a plan to take all these departments and throw them onto what is currently known as ICIS. ICIS is a radio network that utilizes not only digital and analog voice but trunking and conventional technology. Currently there are roughly a dozen cities that have moved their systems to ICIS and hopefully within the next four years the remainder of Los Angeles County as a whole will have moved over (with the exception of some city services) to complete what is to be known as LA-RICS, the Los Angeles Regional Interopable Communication System.
The final draft report of what the LA-RICS system will look like can be found here
http://la-rics.org/Radio_Interoperability_Project_Final_Report.pdf
In the end LA-RICS will likely end up becoming the largest mixed mode communications system in this country, if not the world.
