SDRTrunk Losing audio
Forts
Ontario, Canada
Audio drivers are NOT even the most remote reason (in the entire universe) why the sound drops out after a few hours on SDRtrunk HAHAHAHAHAH b/c all other audio plays perfectly. I will bet my money that the reason is b/c SDRtrunk is in version 0.6.0 Alpha, which is barely halfway to version 1.
LOLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL @ Chris
Wow... that's one way to show appreciation for the folks that are trying to help you out.
rlmurray56
Puyallup, WA
My 3 Nooelec's go up to 2.8 MHz & the last thing I'm gonna do is turn them down. Even if I have to get a powered hub for it to keep up w/ the data, I have my non-powered 3.0 hub plugged into a 3.1 port already.
whatever dude, then don't try suggestions. it is not a major bug as you said, many many other users run this software trouble free 24/7 as do I. Seems like a hardware problem or settings problem on YOUR end. Good Luck.
Which Nooelec's do you have? I have been running my smarts and smart T at 2.56. I may try higher to actually free up a dongle.
Hey, Is there a reason that you are running SDRTrunk and TrunkRecorder both at the same time? No hate genuenly just wondering, when SDRTrunk has a record feature built in.
Is your Java updated to the latest version?
Indianabrad
Jasper County, IN.
For me, who is just running SDRTrunk and not streaming or recording, it has really made a diff to have did the major suggestion of this thread & turned up the ram in the JVM to 4 gigs, it even made the audio clearer & my SDRTrunk hasn't since ran out of ram over night & crashed & closed.
dave3825
Suffolk County NY
@LateNightGaming
Not understanding how your asking about me running sdrtrunk and trunking recorder at the same time from what you quoted.
" Which Nooelec's do you have? I have been running my smarts and smart T at 2.56. I may try higher to actually free up a dongle. "
In any event, I know it has a recorder but I cant listen live as the audio stops working on Sdrtrunk after a few hours. I use trunking recorder to basically listen live even though there is a slight delay that way. I am open to any suggestions. How exactly to I check my Java version? What I found on the web is not yielding any success.
@LateNightGaming
My fault on the quoting one-I didn't mean to quote that part. Regardless, since your running windows 10, you can Simply do a search for "Java" in the start menu and it should pull up a "Check For Updates" option as shown:
If that fails to work, you can always simply re-download Java, as it would update it regardless. A re-installation of Java may help as well, as that would in theory tell us that the JVM may not necessarily be the problem (If we are lucky here)
***EDIT***
Pardon if I am interprerating this incorrectly, but are you saying when you run the recorder is when you get audio issues? Or am I misunderstanding.
dave3825
Suffolk County NY
I can run sdrtrunk and record and listen. After a few hours the audio just stops. It still records and everything else works, just cant listen live. If I use trunking recorder, and import the recordings that sdrtrunk is recording, I can listen.
As far as java, I do not seem to have an app called java nor do I have anything related to java in the environment variables. I know with older versions you had to install Java but the sdrtrunk page says,
Starting with Version 0.5.0 Alpha 2, you no longer have to install Java and compile the JMBE library. sdrtrunk now has integrated support for creating the JMBE library.
This is what I get when I start sdrtrunk. I have never seen any error message after the ausio quits.
Code:
14:51:53.801 INFO  i.g.d.icon.IconModel - loading icons file [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml]  [11MB/124MB 9%]
14:51:53.807 INFO  i.g.d.icon.IconModel - Icons file not found at [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml]  [11MB/124MB 9%]
14:51:54.011 INFO  i.g.d.log.ApplicationLog - Application Log File: C:\Users\Preferred Customer\SDRTrunk\logs\sdrtrunk_app.log  [19MB/124MB 15%]
14:51:54.049 INFO  i.g.d.log.ApplicationLog - SDRTrunk Version  : 0.5.0-alpha6  [22MB/124MB 18%]
14:51:54.050 INFO  i.g.d.log.ApplicationLog - Gradle Version    : Gradle 6.3  [22MB/124MB 18%]
14:51:54.050 INFO  i.g.d.log.ApplicationLog - Build Timestamp   : 2020-10-26T04:29:57.816-0400  [22MB/124MB 18%]
14:51:54.051 INFO  i.g.d.log.ApplicationLog - Build-JDK         : 15 (BellSoft 15+36  [22MB/124MB 18%]
14:51:54.051 INFO  i.g.d.log.ApplicationLog - Build OS          : Linux (amd64 4.4.0-193-generic  [22MB/124MB 18%]
14:51:54.051 INFO  i.g.d.log.ApplicationLog -   [22MB/124MB 18%]
14:51:54.051 INFO  i.g.d.log.ApplicationLog - *******************************************************************  [22MB/124MB 18%]
14:51:54.051 INFO  i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application ***  [22MB/124MB 18%]
14:51:54.052 INFO  i.g.d.log.ApplicationLog - ****  website: https://github.com/dsheirer/sdrtrunk             ***  [22MB/124MB 18%]
14:51:54.052 INFO  i.g.d.log.ApplicationLog - *******************************************************************  [22MB/124MB 18%]
14:51:54.052 INFO  i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%]  [22MB/124MB 18%]
14:51:54.052 INFO  i.g.d.log.ApplicationLog - Host OS Name:          Windows 10  [22MB/124MB 18%]
14:51:54.053 INFO  i.g.d.log.ApplicationLog - Host OS Arch:          amd64  [22MB/124MB 18%]
14:51:54.053 INFO  i.g.d.log.ApplicationLog - Host OS Version:       10.0  [22MB/124MB 18%]
14:51:54.053 INFO  i.g.d.log.ApplicationLog - Host CPU Cores:        8  [22MB/124MB 18%]
14:51:54.054 INFO  i.g.d.log.ApplicationLog - Host Max Java Memory:  2 GB  [22MB/124MB 18%]
14:51:54.054 INFO  i.g.d.log.ApplicationLog - Storage Directories:  [23MB/124MB 18%]
14:51:54.054 INFO  i.g.d.log.ApplicationLog -  Application Root: C:\Users\Preferred Customer\SDRTrunk  [23MB/124MB 18%]
14:51:54.055 INFO  i.g.d.log.ApplicationLog -  Application Log:  C:\Users\Preferred Customer\SDRTrunk\logs  [23MB/124MB 18%]
14:51:54.055 INFO  i.g.d.log.ApplicationLog -  Event Log:        C:\Users\Preferred Customer\SDRTrunk\event_logs  [23MB/124MB 18%]
14:51:54.056 INFO  i.g.d.log.ApplicationLog -  Playlist:         C:\Users\Preferred Customer\SDRTrunk\playlist  [23MB/124MB 18%]
14:51:54.057 INFO  i.g.d.log.ApplicationLog -  Recordings:       C:\Users\Preferred Customer\SDRTrunk\recordings  [23MB/124MB 18%]
14:51:54.057 INFO  i.g.d.util.ThreadPool - Application thread pool created with [8] threads  [23MB/124MB 18%]
14:51:54.066 INFO  i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\Preferred Customer\SDRTrunk  [5MB/124MB 4%]
14:51:54.074 INFO  i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties]  [6MB/124MB 4%]
14:51:54.075 INFO  i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties]  [6MB/124MB 4%]
14:51:54.089 INFO  i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\Preferred Customer\SDRTrunk\settings\settings.xml]  [6MB/124MB 5%]
14:51:54.325 INFO  i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations  [11MB/27MB 42%]
14:51:54.413 INFO  i.g.d.s.t.TunerManager - LibUSB API Version: 16777478  [12MB/27MB 45%]
14:51:54.414 INFO  i.g.d.s.t.TunerManager - LibUSB Version: 1.0.22.11312  [12MB/27MB 45%]
14:51:54.555 INFO  i.g.d.s.t.TunerManager - discovered [10] attached USB devices  [12MB/27MB 45%]
14:51:54.561 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [8087:8008] Hub Device  [12MB/27MB 47%]
14:51:54.561 INFO  i.g.d.s.t.TunerManager - USB Bus [3] Device [8087:8000] Hub Device  [12MB/27MB 47%]
14:51:54.562 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [046D:C52F] Unknown Device - Class 0  [12MB/27MB 47%]
14:51:54.562 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [413C:2111] Unknown Device - Class 0  [12MB/27MB 47%]
14:51:56.065 INFO  i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2560000.0] providing [102] channels at [25098.0] Hz each  [14MB/27MB 53%]
14:51:56.201 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [0BDA:2838] LOADED: RTL2832 SDR/R820T 00000001 Max Rate:38400000 bps  [14MB/27MB 53%]
14:51:56.202 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [8086:8C31] Hub Device  [14MB/27MB 53%]
14:51:56.216 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [0BDA:2838] Unknown Device - Class 0  [14MB/27MB 55%]
14:51:56.216 INFO  i.g.d.s.t.TunerManager - USB Bus [3] Device [8086:8C26] Hub Device  [14MB/27MB 55%]
14:51:56.247 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Device [1D50:60A1] LOADED: Airspy 04A464C8-342F810B Max Rate:320000000 bps  [15MB/27MB 56%]
14:51:56.248 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [8086:8C2D] Hub Device  [15MB/27MB 56%]
14:51:56.248 INFO  i.g.d.s.t.TunerManager - -------------------------------------------------------------  [15MB/27MB 56%]
14:51:56.249 INFO  i.g.d.s.t.TunerManager - USB Bus - Potential Maximum Data Rates  [15MB/27MB 56%]
14:51:56.251 INFO  i.g.d.s.t.TunerManager - USB Bus [2] Rate [358400000] bits per second *** WARNING ***  [15MB/27MB 56%]
14:51:56.251 WARN  i.g.d.s.t.TunerManager -
                * WARNING: the combined data rates of tuner(s) on USB bus(es) above can potentially saturate or exceed
                * the maximum USB 2.0 data rate of 480 Mbps.  This can cause data loss and severely impact decoding
                * performance resulting in missed calls and stuttering audio.  Recommend moving tuner(s) to other
                * USB ports/buses to better balance data rates across available USB buses.
                ******************************************************************************************************  [15MB/27MB 56%]
14:51:57.236 INFO  i.g.d.p.PlaylistManager - Loading playlist [C:\Users\Preferred Customer\SDRTrunk\playlist\default.xml]  [14MB/30MB 48%]
14:51:57.455 INFO  i.g.dsheirer.gui.SDRTrunk - starting main application gui  [17MB/30MB 57%]
14:52:02.104 ERROR i.g.d.g.p.s.StreamingEditor - Unable to refresh broadcastify stream configuration(s)  [53MB/107MB 49%]
14:52:09.883 INFO  i.g.d.a.c.m.JmbeAudioModule - Loading JMBE library from [C:\Users\Preferred Customer\SDRTrunk\jmbe\jmbe-1.0.7b.jar]  [117MB/183MB 64%]
14:52:09.895 INFO  i.g.d.a.c.m.JmbeAudioModule - JMBE audio conversion library loaded: JMBE Audio Conversion Library v1.0.6  [117MB/183MB 64%]
14:52:09.895 INFO  i.g.d.a.c.m.ImbeAudioModule - JMBE audio conversion library IMBE CODEC successfully loaded - P25-1 audio will be available  [117MB/183MB 64%]
14:52:09.918 INFO  i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [6000000.0] providing [240] channels at [25000.0] Hz each  [118MB/183MB 64%]
14:52:09.971 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [85MB/183MB 46%]
14:52:10.770 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [136MB/245MB 55%]
14:52:11.785 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [144MB/245MB 58%]
14:52:12.906 INFO  i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread  [158MB/245MB 64%]
14:52:13.930 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [161MB/245MB 66%]
14:52:15.461 INFO  i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2560000.0] providing [102] channels at [25098.0] Hz each  [152MB/245MB 62%]
Here are a few things to try:
Saving your Playlist file someplace safe and reinstalling the latest version of SDRTrunk
DO try reinstalling your Audio Drivers via device manager, as it is completely possible that an update was pushed out that may have broken something
Ensure everything is updated and happy as far as Windows Update goes
Check your Audio Output Devices
Make sure that your computer display is not going to sleep
This is about all I can suggest. Im sorry I cant be of more help, The final thing I can offer is to maybe use OP25 or TrunkRecorder as your new main program? Let me know how it goes, and ill keep attempting to provide support any way I can.
lockersdr
Detroit, MI
Code:
Any luck yet, I run an air spy as well and have the exact same issues. I have to restart every 8 hours or so otherwise the control channels quit following the talk groups.
dave3825
Suffolk County NY
No luck. I start it up, set it to mute and let the tg's of interest record. If I am here I listen thru trunking recorder. It funny, its been running for 2 weeks and if I unmute it plays but than after a few hours it stops.
