I took a look at the Favorite List
@J-Wrock sent and a couple of things I noticed.
First...is GPS enabled? I see Location Control is on for the Departments, and I don't know if that will cause problems since I don't use GPS much.
Second...I see J-Wrock has used Quick Keys (as I do) to isolate departments. KC Fire is under Quick Key 11 and the entire system under Quick Key 0. Depending on if you assigned a Quick Key to this Favorites List, it would go like this if you chose the Favorite List Quick Key as 1:
Favorite List QK-1/System QK-0/(City of KCMO) Department QK-11
(1.0.11 E/Yes) would turn it on or off , if it's already on.. It's possible that the Department Quick Key is Off?
In addition to that, the Sites also have Quick Keys assigned:
90 is Johnson Simulcast and 91 is Jackson Simulcaast. It's possible the one you want to use for Fire is off.
(1.0.90 E/Yes) and/or 1.0.91 (E/Yes).
Let me add an edit to this. If you didn't assign the Favorite List a Quick Key, Decimal First:
(.0.11 E/Yes) Decimal-Zero-E/Yes.
