Loudoun Fire CTCSS?
rirri
Purcellville
Is Loudoun County fire still using CTCSS on their VHF freq (46.380)? I have it programmed into my 396 with CTCSS on and hear nothing until I disable it. Unfortunately, without it I pick up so much interference in the computer room I have to lockout the channel.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
in the RR DB...
http://www.radioreference.com/apps/db/?ctid=2872
N2NAR
Warrenton, VA
Actually Loudoun switched to a simulcast transmitter system on 46.38 several months ago. When they did this, they no longer transmit the CTCSS because it is harder to syncronize the transmitters when you also tx a tone. So you must listen in CSQ. They used to manually simulcast before, but the transmitters were not syncronized and beat against each other. Transmissions used to sound horrible and were often unintelligible.
mike_s104
thanks for the correction. you could submit that to the DB so we all have good info.
that might explain why I haven't heard them on that freq in a while.
tglendye
Blue Ridge Mountains, Shenandoah River- VA
N2NAR said:
...they no longer transmit the CTCSS because it is harder to syncronize the transmitters when you also tx a tone. So you must listen in CSQ. They used to manually simulcast before, but the transmitters were not syncronized and beat against each other. Transmissions used to sound horrible and were often unintelligible.
Good info all around... thanks. That explains some things locally and also why Augusta County (460.550), who also has multiple dispatch sites, dispatches CSQ.
rirri
Purcellville
Thanks for the info. I'm disappointed I have to miss calls when next to the computer, but at least I understand why.
