LPE-200 error code help
electricsheep
electricsheep
Does anyone know what the error code DIGV ERR means on an LPE-200 when attempting to be used on a provoice system? According to this radio's feature string it has option 29, Provoice IMBE.
Is this unit just misprogrammed or does it speak to something worse?
MASTRTECH
South Louisiana
The radio is programmed wrong. Go into systems, under the general tab select provoice as the vocoder. Also, go to group sets and select unencrypted on all talkgroups. I hope this helps.....mastrtech
electricsheep
electricsheep
I will let you know. Thanks a lot...
MASTRTECH
South Louisiana
No problem.Do you have the software and TQ3370. I looked at a personality and verified that info. Sometimes when we add a talkgroup or system, you forget to select the correct vocoder and......digverr!
MASTRTECH
South Louisiana
