M/A-Com NetworkFirst
INDY72
Indianapolis, IN
Anyone know if this IP based solution for interoperability is all its being touted as? I know Washington State Police have been working with M/A-Com to set up a NetworkFirst system there, any news on if its working out?
unitcharlie
a Kentucky DB Admin...
far from Nonesuch, Ky...
with apologies....
milf:
this is a news item i posted a while back.... i have seen a few of their demonstrations, it works rather well if everything in the system is working.... i have a little trouble with the system because it is "secure"... didn't have the chance with my scanner to find out how secure because had to do the story and get to the next assignment.... it is a good idea, just hope it doesn't become so proprietary that no one can use it because of the licensing restrictions.
this is the url:
http://www.radioreference.com/modules.php?name=News&file=article&sid=246
INDY72
Indianapolis, IN
OK TY,.. I would assume Motorola has a simular IP based interop system.
INDY72
Indianapolis, IN
TY!
Now as for Secure,.. well its IP based, so the actual interfaceing is not over the air,.. thus no scanner can listen to the IP part..... But the actual transmitted radio part should be scannable unless M/A-Com uses a conventional form of Provoice.
N
N_Jay
Guest
milf said:
TY!
Neither of these affect the over-the-air portion (other than using some addressing, channel, or coded squelch information).
