M150 - No Receive
Jacksonechols55
Hello,
I have a BK M150 that has been working fine until today it will not receive any audio at all. Does anyone have any ideas?
This was sent to BK early in 2022 to have some repairs made to the guts and to be realigned and tuned.
rsmith7799
Arroyo Grande, CA
IS this a DASH or REMOTE mount? Can you get to the audio plugs and make sure they are snapped together? .....sorry, just trying to look at the simple things first. Another thing is to reinstall the Software and/or update it to the latest and greatest version. 5.7.7 for the Firmware and 5.8.30 for the Software. These were added on 7/14/23. See if this works...
Jacksonechols55
It is a dash mount. I have updated to new firmware still nothing then also downgraded to older firmware still nothing. I haven't opened the radio yet, that will be my plan this evening.
rsmith7799
Arroyo Grande, CA
Have you looked at the wiring t......I was going to say something but my brain kicked in and i remembered.......look at the software and make sure that the HCH MASTER VOLUME is not checked. This was an issue.
Jacksonechols55
It has not been programmed recently it shouldn't have anything to do with programming.
I have attempted to take it apart but it won't come apart acts like it stuck.
TurboSportTSi
Do you get a receive indication on the screen? RXA or RXD in the upper left hand corner.
TurboSportTSi
If nothing else has changed, then it sounds like something in the RF portion is fried.
Can the radio transmit OK? Could just be the antenna relay, but I'd assume they would fail with the receive open and not passing the transmit.
It almost doesn't matter at this point, as it needs to go back to the mothership unless you're going to DIY the repair.
Jacksonechols55
Does transmit but gets locked up on the display. Just had everything inside replaced a little over a year ago... around $800 and about 4 months... not sending it back again lol.
2154
What Rick said. I've seen a couple where the audio plug off the back comes off and is a simple fix. Doesn't require opening the radio at all. There's usually two spots for a speaker as well off the little accessory plug.
TurboSportTSi
This is true, but if the radio has no receive indication, it's an RF issue, not just audio output.
Jacksonechols55
Its not a speaker issue. It has sound for the keypad beeps and channel rollover tone. It's an inside gut issue.
