M7100 Orion Convert
Muxlow
Super Secret
Middlesex County
I have a remote mount orion radio, and a front mount M7100. How can i make the M7100 into a remote mount with the orion cables? Or how do i put the orion head on the M7100?
Back of the M7100 has a smaller DB cable then the Orions 37 pin one, same with the ribbon cable for the control head. The M7100 is 2 "pins" smaller then the orion so not sure how this is done. But i know it can be done :)
Radioman96p71
Well, to make the M7100 remote mounted, just take the head off and put the blank plate back in its place. The cables will work just the same.
To mount the Orion head on the M7100 you will need the new ribbon cable that has the contacts on one end and the plug to go to the logic board on the other.
A M7100 can be a drop-in replacement for an Orion remote mount. The pinouts are exactly the same. The M7100 front mount kits are different tho, with the main difference being the ribbon cable going from the logic board to the back of the control head.
Muxlow
Super Secret
Middlesex County
Here are some pictures to help.
2470 Is the Orion Control head and remote mount bracket
2474 Is the Orion control board and the faceplate of the M7100
2476 Is the Orion remote cable and the rear of the M7100
So from these i dont see how these will just fit at all :( Unless i rig up my own cable to connect from the orion to the m7100 to make it a remote setup
And guess i would need that convert thing for the faceplates. Even if i cant get the orion system control head onto the M7100 thats ok. I can deal witht eh scan M7100 head as a remote. Just anyway i can make the front into a remote is all i want really..
timkilbride
Linn Co Iowa
Are you sure "2476" is a M7100? What the tag say for model?
Tim
Muxlow
Super Secret
Middlesex County
Yep. Top is the M7100 bottom is the orion cable
Tags
Harris Corp
Model MAMW-SDMXX
Ser #
IC
FCC ID OWDTR-0051-E
Cage 1PNR4
RU144750-061 RevQ
M7300/M5300
There is my problem lol
One of them things.. i KNOW its a m7300 but keep calling it a M71.. FML :D
Radioman96p71
Ah well then disregard everything i said, it doesnt apply to you haha.
Muxlow
Super Secret
Middlesex County
Yeah no wonder these cables arnt working.. Im like WTF these guys talking about!
Then oh.. there is my problem.. haha
So i assume the orion cables wont work on the 7300's
Radioman96p71
Nope, those are apples to oranges different. Control heads arent even in the same ballpark. Unfortunately you will need to aquire new accessories.
LMR_Dude
At least programming wont require a new cable, the DB-9 above the 44 pin is your programming port.
Muxlow
Super Secret
Middlesex County
Well im glad i spent almost 100 bucks on getting this orion haha
Not a damn thing i can use it for either.. Ahh.. Details :D
Ill guess its $$$ costly to get a remote kit for this M7300?
