OP25 Major New OP25 Release - Seeking Beta Testers
KA1RBI
Portage Escarpment
Code:
linux; GNU C++ version 7.3.0; Boost_106501; UHD_003.010.003.000-0-unknown
gain: name: LNA range: start 0 stop 0 step 0
setting gain LNA to 37
supported sample rates 250000-2560000 step 24000
tuskin@tuskin-Inspiron-700m:~/op25/op25/gr-op25_repeater/apps$
From the above it appears rx.py is ending and since there's no suggestion of a keyboard interrupt the conclusion is it must be quitting due to some error.
Any messages in the stderr file?
Max
Paco-Jerte
You Member, Member!
34.0500° N, 118.2500° W
Max
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.11
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Found Rafael Micro R820T tuner
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
[R82XX] PLL not locked!
Traceback (most recent call last):
File "./rx.py", line 873, in <module>
rx = rx_main()
File "./rx.py", line 796, in __init__
self.tb = p25_rx_block(self.options)
File "./rx.py", line 161, in __init__
gain = int(gain)
ValueError: invalid literal for int() with base 10: '37\xe2\x80\x99'
KA1RBI
Portage Escarpment
The gain value you've specified (LNA:37) is evidently followed by what looks like a regular apostrophe - but has hex values of e2xxx instead of the proper ASCII value (hex 27). This can sometimes happen if the text is pasted from a "rich text" source or a web page, etc.
You'll have to edit the file - *all instances* of these non-ASCII characters must be excised.
Max
Paco-Jerte
You Member, Member!
Max
hmmm ok, never had this issue before with c/p commands in the past with other versions of op25.
mkmer
Anyone having issues with Ubuntu 20.04.01LTS?
I just upgraded (from 20.04 which was working). OP25 quit working, so I uninstalled, updated my local repo (which was already up to date), confirmed patch 3.8 patch was installed, and rebuilt OP25 with install-gr3.9.sh. Now rx.py appears to hang at launch, and multi_rx.py and http_server.py tosses a "illegal instruction (core dumped) fault at launch.
Everything compiled nice - other than a few warnings.
mkmer
Following up on Tuesday post... looks like multi_rx.py strace ends with:
read(3, "", 1024) = 0
close(3) = 0
getrandom("\xbd\x21\x70\x1d\x79\xb9\xc8\xad", 8, 0) = 8
--- SIGILL {si_signo=SIGILL, si_code=ILL_ILLOPN, si_addr=0x7fb9c3b50660} ---
Maybe getrandom function is somehow broken?
As described in README, rx.py is exhibiting the timeout issue - so I guess that's known.
WX4JCW
Stow, Ohio
ok im stumped - when i go to click and edit a SUID i get the following error
Source tag TSV file not specified in config file. Cannot edit.
any ideas?
Outerdog
T¹ ÆS Ø
any ideas?
Pretty self-explanatory. You have to specify the tsv file for the source ID tags in the trunk.tsv file. It goes in the "TGID Tags File" field, and is a comma-separated value alongside the talkgroup tags value.
For example:
Code:
"Sysname"    "Control Channel List"    "Offset"    "NAC"    "Modulation"    "TGID Tags File"    "Whitelist"    "Blacklist"    "Center Frequency"
"EBRCS CCCO Central"    "774.45625,773.90625,774.18125,774.73125"    "0"    "0x1F5"    "CQPSK"    "ebrcs-tg.tsv,ebrcs-su.tsv"
mkmer
Just did a clean install on Ubuntu 20.04, having issues with the flask logging:
Code:
File "/op25/op25/gr-op25_repeater/apps/oplog/op25/__init__.py", line 57, in <module>
    db.reflect(app=app)
TypeError: reflect() got an unexpected keyword argument 'app'
Maybe a newer version of SQLAlchemy than expected?
Outerdog
T¹ ÆS Ø
There is a patch for this which should be posted to the repo soon. I haven't tested this yet.
Save the file and use git apply to apply the patch.
Code:
diff --git a/op25/gr-op25_repeater/apps/oplog/op25/__init__.py b/op25/gr-op25_repeater/apps/oplog/op25/__init__.py
index 4c6b257..9e34798 100644
--- a/op25/gr-op25_repeater/apps/oplog/op25/__init__.py
+++ b/op25/gr-op25_repeater/apps/oplog/op25/__init__.py
@@ -51,12 +51,13 @@ app.config['SQLALCHEMY_ECHO'] = False  # set to True to send sql statements to t
app.secret_key = b'kH8HT0ucrh' # random bytes - this key not used anywhere else
db = SQLAlchemy(app)
+db.init_app(app)
-try:
-    db.reflect(app=app)
-    db.init_app(app)
-except OperationalError as e:
-    raise(e) # database is locked by another process
+with app.app_context():
+    try:
+        db.reflect()
+    except OperationalError as e:
+        raise(e) # database is locked by another process
class MyDateType(types.TypeDecorator):
     impl = types.REAL
Credit to Bill (I think).
  • oplog.zip
mkmer
Code:
+db.init_app(app)
-try:
-    db.init_app(app)
+    try:
+        db.reflect()
     impl = types.REAL
Works like a champ!
I didn't see this anywhere on google - hope this will help others too.
Outerdog
T¹ ÆS Ø
Works like a champ!
Thanks for the report back.
This issue just cropped up within the last few days.
CanesFan95
Analog already is interoperable.
FL
Is there a way to know if there's a newer version available so we can know when to do an update?
wgbecks
NE Wisconsin
You can periodically check the the website for recent updates or simply perform a git pull from the ~/op25 folder.
