Making a CPS multi-region. Solution for "CPS area doesn’t match".
YL3IM
KO26BX
In Windows Explorer, open the CPS installation folder.
Proceed to the config subfolder.
Open tle last archive (either .zip or .7z) inside it.
Open the Model.dat file inside the archive.
Locate the line with [Area] inside the Model.dat file.
Replace the lines below with:
Number=5
Area0=0
Area1=2
Area2=5
Area3=6
Area4=8
Save the Model.dat file into the archive.
Now the CPS should become multi-region. 🙏
Don't worry if the fonts inside the CPS become weird — it's expected and it's considered ok.
Bowlieweekender
Encryption is Easy - Key Management is Hard
Prineville Oregon
I just got an X1p and I'm having to use Clone to get around it being the wrong region for my NA2 CPS. Thanks YL3IM
Bowlieweekender
Prineville Oregon
I tried it on V9.02.21.000.im.NA2 and it says it worked looking at the About box now, but it still refuses to write to the Australian X1p, so the mystery continues. HACKED.jpg
Bowlieweekender
Prineville Oregon
OK solved all my issues with a firmware upgrade using V8.00.06.007 NA and now it reads and writes via the CPS correctly and I finally managed to overwrite the previous Radio Alias
YL3IM
KO26BX
Firmware upgrades are region agnostic whereas CPSes are region specific by default. The latest FW for PD/MD/X1p radios is 9.02.04.001 as of now.
