Making a Unity / M7300 Mobile 44-pin Speaker Cable - Help
prcguy
“Buffered Filtered Discriminator Audio Output (typically not used). A fixed-level audio output with DC bias. Approximately 200 mV rms into a 600-ohm load at rated deviation. Does not contain signaling (e.g., CTCSS). Mutes when speaker mutes. Use a 33μF/50V (or greater) AC-coupling capacitor to couple to a 600-ohm load. Use P4 pin 12 for ground.”
From the manual.
-B
You would need the cap when feeding an isolation transformer.
brian86
Maryland
So I have all the parts in hand... I have the Capacitor and I have the transformer, How exactly would I hook this up? is their an example or a schematic available to properly hook to the FDISC Output?
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Someone want to test the aux audio in lines and tell me if it works? Manual says it sums the input with the radio's output. Might be a fun way to run the line out from a scanner through the radio's higher power audio amp and share a single speaker with the Harris.
redbeard
BEE00.348-3.1
That's Pin 4 for input on the 44-pin and using pin 1 or 6 as the signal ground. PIN 4 - EXTRX - EXTERNAL RX AUDIO INPUT (FROM EXTERNAL/2ND RECEIVER, SUMMED)
redbeard
BEE00.348-3.1
I tried before with a quick and dirty clip lead setup with no luck. But I think since it inputs to the radio deck directly it's probably only summed with the audio output of the radio itself. I was using remote heads, where the audio amp is in the head which is probably why it didn't work. I doubt the ext rx audio is encoded and sent out the CAN network to remote heads. And I didn't have a speaker on the brick to test it.
