Manipulating entries in scanlist
kb8uih88
Can entries be moved or reordered in a scan list? TRX-.2 scanner? Can't see how to do it
kb8uih88
OK. TNX. Another question? How do I make sure talklists are attached to the correct group of frequencies for that repeater system
tvengr
Well Known Member
Baltimore County, MD
When you click on a trunked system and the Talkgroup Details tab, you get the talkgroups associated with that system.
tvengr
Well Known Member
If you have multiple sites programmed for a system, the scanner receives only the site with the best signal. The frequencies go into the sites.
kb8uih88
Right, but how does the scanner know that scanlist 1 is supposed to be associated with bank 1 in the scanner? I'm dealing with 50 some counties in my state. I don't need the scanner scanning every frequency I programmed and not every talkgroup in memory.
hiegtx
Dallas, TX
In EZ-Scan, look in the talkgroup listing for a given trunked system. There, you'll see which scanlist that TGID is under.
For conventional frequencies, either look at the overall Conventional Frequencies tab. It shows all the conventional frequencies programmed, and the scanlist each is assigned to.:
If a specific talkgroup or conventional frequency is associated with more than one scanlist, those lists would be separated by a comma between each assigned list.
kb8uih88
OK, that helps me a lot. Thank you for your patience. I was trying to understand how this all worked. Do you know how the scanlist and talkgroups are associated to a specific trunking site?
hiegtx
Dallas, TX
You "associate" the talkgroups to a given site (or sites if the system has more than one site). Each site is listed separately under the Site Details tab in the trunked system editor.
If you then select the Talkgroup Details tab, you'll see all the programmed TGIDs that are associated with that system.
Your talkgroups must be associated with the correct system in order to hear them on one of the site's frequencies. This is where you assign the scan lists you want for the talkgroups.
dispatch235
Central Missouri
