Manually Deleting Scanlist
VE3NMW
London Ontario
I have a TRX2 and need to manually delete a Scanlist and can’t find anything out there on how to do it??
Whiskey3JMC
Quiet numbskulls I'm broadcasting!
Simulcastylvania, TE
Been a while since I've owned a TRX but if I recall you can't delete a scan list per-se but rather empty (or delete) the objects contained within. Pages 41 & 42 of the user manual
Editing Objects Manually
From the main menu, select Browse Objects, browse to an object and press Menu.
Delete Object Removes the channel from EZ Scan’s working memory. The channel remains in the library data
I'm sure I'll be quickly lambasted if I'm wrong :ROFLMAO:
TAbirdman
MO
On the radio you will have to delete each object individually. With the software you can select all objects the hit the delete button. Super quick and easy.
Wackyracer
Use ezscan, go to the scanlist tab. select the scanlist, select one item then select everything in that scanlist using ctrl-A, then delete.
You can also just turn off the scanlist by unchecking it under general tab.
VE3NMW
London Ontario
Thank you!!
