Map of all systems in the HomePatrol DB
OCO
Central Michigan
Testing the HP1 "Export to .KML" function....This is the entire HP1 DB.. The big question, is Jay911 ever home (or is the Province of Alberta the only place in Canada with radios?):D
mass-man
trying to retire...
Parker Co., TX
He would seem to be everywhere in Alberta...much kilometers!!!!
That is very nice....thanks
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
LOL. :) That looks bizarre. No point in having stuff in the DB if it's not got a geolocation tag.
I did a ton of work in that regard when I was a DB admin.. and obviously it was worth it! :)
OCO
Central Michigan
And that's without (Tower) Sites.... Sentinel only pulls (TalkGroup) Channel locations for the .kml export.
Edit:
(I'm starting to think there's a conspiracy against tower location information - Homeland Security at work?:D}
torontokris
Toronto Canada
Jay911 excels for sure in the radio world..
but southern ontario has our fair share as well... you cant even see the border between canada and the us between Toronto-Niagara Falls and Buffalo.
OCO
Central Michigan
Ok wheres the link to the map? Seems AWESOME!
Sentinel --->File--->Export to .KML Follow the prompts and check the box to open Google Earth. (Have fun setting up what it'll pull - hint - it's all in what you set in the profile..)
You need to have Google Earth installed.
I use a screen grabber (Snagit) to grab the clips for publishing.
