maratrac program cables
quickshooter45
Banned
other than motorola cable and rib. is there a reliable way to program with generic cable or rib?
where to get generic at.?? anyone have good luck with ribless??
KX5MOT
Lincoln County, OK
You can get aftermarket programming cables on eBay all day long, though i would stick with OEM. Maratrac uses the same cable as the Maxtrac/Radius.
quickshooter45
Banned
thanks
I found sandys rib he makes to be a way to go also. thanks for info..
steele_lpd
Center Barnstead, NH
I have been using the cable below for about a year and have had no problems at all.
http://cgi.ebay.com/Programming-cab...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
zz0468
Banned
Stay away from the ribless cables for DOS RSS programmed radios. You can get a RIB clone on eBay for about $35. They work fine. A lot of the cables, like the Maxtrac/Maratrac cable, you can make yourself - diagrams on batlabs.com.
