Marin County trunked system
JoeyC
Senior Member
San Diego, CA
The other day I was in San Rafael and Sausalito trying to monitor the system and my 796 would not capture the control channel. I could hear things conventionally. I only programmed the EAST zone system.
The freqs were all programmed as trunked, bank set as a UHF system with the base,spacing and offsets set as listed on RR.com. Anybody see anything I did wrong? or is this even system working?
northzone
Northern California
The system has strong signal levels in nearly all of the county (even south county without the Tiburon tower online).
I am assuming you set the tables up with two frequency ranges, this is what confusses most people.
WayneH
Forums Veteran
Super Moderator
Your master site
northzone, that's for a PRO-96 only.
Joey, it's a programming issue definitely though. I'm just not Uniden proficient enough to offer advice.
-Wayne
