Bill - I believe the Mason County Sheriff's Dept. has digital radios, or is in the process of getting digital radios. However, they are currently still talking a lot on the analog UHF system. Either they haven't fully transitioned to the digital radios, or they only use the digital system on a limited basis. I do not know what type of digital system they have - whether it is part of the WVIRP system or something else.
As for the Flatrock and Leon FDs - my personal expectation is for them to stay primarily analog for years to come. There is a PowerPoint presentation on the Mason County 911 web site which talks about the need to "reband" the county's analog radio system by 2013 to meet a federal mandate. The fact that the county is making the effort to reband the existing analog system is a pretty good indication that they will continue using it for awhile. The fire departments will have to buy new analog radios that are compatible with the rebanding. In fact I know at least one of the other fire departments in the county has already purchased a new set of analog radios that will work with the rebanded system.
I'm pretty sure the cost of buying expensive digital radios is an incentive for many volunteer fire departments to stay analog for awhile.
Radio Shack happens to have the Pro-197 on sale for $70 off through tomorrow. Just FYI. If a digital scanner doesn't fit into your budget right now, you might consider getting a used analog scanner (from ebay, for example) rather than buy a new scanner now and then another new one later. Just a suggestion. It would probably be best to get a relatively modern scanner that supports rebanding.
How far south in the county are you? I'm not sure that people living close to the Cabell County line would be able to pick up Leon and Flatrock.
You might want to check out the web site at
Mason County Office of Emergency Services for more information on the county's radio system.
