MCC 7500 Volume Issue
medicfire1
We recently switched to the Motorola MCC 7500 Elite Dispatch. We have 7 consoles and if one of the other consoles has the channel the dispatcher is talking on selected we are hearing the dispatchers voice coming from the computer CPU at the other console and it is giving us an echo effect. The field responders voices are not coming from there only the dispatchers voice. Our local dealer is not sure how to correct the issue. Didn't know if anyone else has that issue and have a fix for it?
talviar
Uniontown, PA
Sounds like your dealer doesn't know how to set the consoles up. . . . .
Audio Cross Muting for Consoles and RF Channels and such need set up.
I am not sure on Conventional only setups. But if your MCC7500 is on a trunking system, you need to set this in Provisioning Manager or UCM (depending on version of your system)
Local Dealer really needs to open up a case with Motorola SSC for support if he isn't sure of what to do.
cmdrwill
So Cali
Sounds like the so-called 'dealer' does not know how to work on that system. Time to get a more qualified person.
esfd283
This is the exact way to handle this. You are having a cross mute issue.
