MD380 cable problem
N0ZQR
Nebraska
Just received a MD380 VHF. Loaded the software off the disk and was able to create a file. Now need to be able to load the file to the radio, but the message window tells me that the usb cable is "busy"
What do I need to do to get the computer to "see" the cable?
Ron
PS: would like to get this running so that I can monitor some Motrbo in the area.
W0JJK
Can you read the radio to save a blank file?
Are you using Tytera software?
Once I got the driver loaded, then it works just by plugging in the radio and computer.
cmjonesinc
Are you using a tyt cable? You have to have an actual tyt cable for that radio. The kenwood and Chinese ones that look the same actually aren't.
N0ZQR
Nebraska
Yes I am using the tyt cable. It's like the computer never loaded the driver.
And am using the disk that came with the radio.
Ron
jonwienke
More Info Coming Soon!
VA
TYT cables have no electronics.
The USB/serial converter is in the radio, so the computer will not detect anything or try to load any drivers until you plug in the cable, connect it to the radio, and turn the radio on.
N0ZQR
Nebraska
I had the radio connected and turned on. It's like the driver in the software never loaded. Also do I need to load both the analog and digital drivers if I only want Moto?
W0JJK
Did you try the USB Driver DMR?
It is the right row of downloads, 7th one down.
jonwienke
VA
There is only one radio driver. It is used whether you are programming digital or analog frequencies.
cmjonesinc
I'm about 99% sure that's the same one I used on my XP and 7 computer and I didn't have any problems. OP you may need to uninstall any previous drivers or go into Device Manager and update to the one from the download. Also, as jonwienke said, there's only one drive for analog and digital.
bharvey2
It's been a while since I programmed my MD380 bust as I recall, there is a specific order in how to connect the radio and start the program. If I remember correctly, you need to connect the radio to the computer via the cable, turn on the radio and then start the CPS program. Reverse order for disconnecting. Doing otherwise will cause trouble and the CPS will not see the radio.
jonwienke
VA
Not true, at least with most recent CPS. With the CPS running, you can plug in a radio, turn it on, and program it as soon as you get the ding from windows indicating that the device is connected. I've programmed several radios in a row in this manner without restarting the CPS.
bharvey2
I can't argue with you as I don't think I have the latest version. It has definitely been a problem for me in the past. - One that I hadn't experienced with other radios/CPS programs. If the OP has the same version as I do, that could be the problem. Thanks for the information though. I'll have to go out and find the latest version because it is pretty frustrating.
