MD380 Frequency Import
I have been using the MD380 as a scanner since a lot of my.local agencies have been moving to DMR mixed in with analog. So this radio works perfect. Is there any way I can import the radio reference frequency into my radio without doing it all manually?
buddrousa
#1 You have to have a Premium Subscription.
#2 You have to have software that supports importing from RR.
#3 I own 4 MD380s and have not seen anyway to do what you want. 2 VHF and 2 UHF
Ubbe
Stockholm, Sweden
N0GSG have coded the DMR Contact Manager that can import from csv files to many different DMR radios including MD380. I do not know what kind of info you can pull from RR but I reckon you could do it as long as you end up with a csv file after some converting, perhaps from excel.
Contact Manager have some nifty functions that let you copy frequencies and add channels very easy and then you read and write the radios codeplug with the standard MD380 program. I always use Contact Manager for editing as it is so much easier to use than the standard MD380 program.
/Ubbe
