MD785 DTMF MIC
N5WMT
Yuma, AZ
Is there any software change required if adding a SM19A1 on the above radio?
headsense
Member - Learner Driver
It's been a long while, and I only have 2x SM19A1's installed on a small fleet of 10x MD-782's all on V9.0 firmware ..........
Read the radio, open codeplug, CONVENTIONAL > GENERAL SETTINGS > BUTTONS and assign desired functions to each key using the drop down menu options noting this instruction only applies to mic left side keys ACC - P1 and ACC- P2 and top mounted key ACC- TK.
N5WMT
Yuma, AZ
Thank you. I have the button issue covered as you described.l was wondering about the DTMF portion and if any CPS changes were necessary.
