prcguy
- Joined
- Jun 30, 2006
- Messages
- 18,935
- Reaction score
- 15,374
You have to use a device to combine them and that will always have a minimum of 3dB loss, actually 3.01029996dB theoretical plus other losses. If you combine two 1 watt signals in phase using a combiner that has 3dB loss you will have very close to 2 watts at the common port. So yes I agree it can happen.Can we first agree that if you add 1watt to 1watt we get 2 watts? Theoretical.
If you combine the same two 1 watt signals with the same combiner and its out of phase due to two different cable lengths you can have nearly zero watts so its all dependent on the phase. But the combiner still has 3dB insertion loss no matter if the signal is passing from the common port to an output or an output to the common port. Explain then how combing two signals in phase can give 3dB gain when the device combining them has 3dB loss? The answer is still you are starting with a 6dB increase by combining two in phase signals but loosing 3dB of it in the hardware combiner leaving you with 3dB net gain. Do you have a different explanation?
I should add that you can never see or realize the 6dB gain from combining two in phase signals because there will always be lossy hardware involved in the combining process. But the 6dB gain is there in theory to explain the resulting potential 3dB gain from combining two in phase signals. Hope that helps.
