Miami dade county
seagravebuff60
Short Bus Reject
Snow Bird
IS the miami dade system still just phase 1
Did you look at the database? Says Phase 1. I would assume the DB is correct. All the TGs are labeled "D" indicating FDMA aka P25 Phase I.
no, it's P2.
No, he's asking about the county system, not the city.
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
yeah, hard to tell. you are correct.
Phase 1
Kitn1mcc
Old Lyme ct
The reason i ask is if you click on the site to get the off set tables its says FDMA and TDMA is this correct or are both FDMA
APX8000
Sarcastic Member
AES-256 secured
Miami-Dade COUNTY is Phase I. The CITIES of Miami and Miami-Beach are Phase II.
I can't see the offset tables because I'm not a premium subscriber. However, if you are referring to Miami-Dade COUNTY P25, there is no TDMA in the Astro 25 Channel ID. The only thing checked should be Channel ID 1 and it should be FDMA -45.00000 12.500 851.00000
Kitn1mcc
Old Lyme ct
ahh ok it says 1 FDMA 2 TDMA thats what made me ask
