MICCOM Trbo
roxfire53
under morris county nj...just click on my profile where it says feed provider
MICOM
I believe Miccom is encrypted.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Why am I always hearing MICOM to ALS then?Busy frequencies!
155.175,155.400,155.280,155.340 these work anywhere really
I shut this off every now and then cause it never shuts up
902
Downsouthsomewhere
They sound pretty good. I've only heard Mototrbo "noise" as interference to analog, and never actually heard it demodulated. Certainly sounds better than 155.175 did. Unfortunately some people seem to mumble.
Is the sound at the beginning of some transmissions a channel grant, like in legacy trunked systems, or does it mean something else (or does it mean nothing)?
I might have spoken too soon. Sounds like there are some issues with some kind of feedback, like it's breaking into oscillation. What kind of receiver are you using?
roxfire53
there is not any information to post. the feed is provided so you guys can listen. you ask they gave.
RadioDitch
Field Operations Member
Not Where You Think
If there is information on what frequencies are being used, it should be in the database whether there is a feed or not. It's not as though it's top secret government communications. It's EMS dispatch.
lion2479
St.Clare's Mototrbo DMR-EMS Dispatch
Does anyone have the color code 1-15 , Talk group number and time slot for this system. I understand there is a live feed but someone must have this information available. You need all three to RX only monitor the system. Tried using DSD+ with no results. Do we know if they are using the One Voice network which Goosetown has a deal with as well? If that is the case, you will be able to monitor the broadcasts all across the tri-state area.
