MicroP25RX
KMG54
Easley S.C.
That is with a heavy simulcast P1 system and no problems. Maybe phase II is more taxing?
robnj74
Buena, NJ
The system I'm monitoring is strictly P2 and I have no issues to report other than a slight garble in audio which I suspect is due to the transmitting tower being just over a mile away.
btt
Jew lover
Wa State
P2 audio doesn't sound as good as P1. It is a "half rate encoder", so it is pretty amazing it sounds as good as it does. You should be able to park under a tower no issues.
robnj74
Buena, NJ
And here I would have incorrectly assumed it should sound better. It does explain why on the NJICS system the state police on P1 sound crystal clear..
btt
Jew lover
Wa State
The amazing thing about P2 is the ability to fit two voice conversations into a single 12.5 kHz RF channel. Obviously, there has to be some trade-off. It can sound pretty good. Obvioulsy, the radios, mics, speakers all play a part in the sound quality. If you are actually having some issues with demod/decode, then it could cause degraded sound as well. You would see a high error rate during voice in this case. For those cases where intermod is an issue, I will be announcing a new product soon.
GTR8000
NY/NJ Database Guy
BEE00
They are not squeezed in side by side as two 6.25 kHz channels, if that's what you're suggesting. They are alternated by time slot, hence the T in TDMA. Each voice slot uses the full 12.5 kHz bandwidth, minus some overhead for signaling. Oh and the AMBE+2 vocoder may be "half rate" compared with IMBE, but that doesn't mean it's worse. In fact, it's better by a number of measures. Just look at the improvements in regeneration of tones. IMBE is much less efficient than AMBE+2, offering less groups for range of tones. AMBE+2 also does better with background noise suppression. But anyway, this really isn't the place to be discussing vocoders I suppose.
maus92
Eastern Shore
Is it always garbling? If not, it could be the SU's location, uplink issue, or a different transmitter or antenna on the same tower that is dominant for your location. It should not be garbling full time.
robnj74
Buena, NJ
I only notice it on one talkgroup and only from dispatch. The responding units are clear.
btt
Jew lover
Wa State
I specifically said "single 12.5 KHz RF channel". lol. How did I suggest otherwise? There are actually 2 slots per channel, so you can fit two voices/slots in a single 12.5 kHz channel (plus some control information). That is the whole point of TDMA. As I said, it is amazing it sounds as good as it does, but P1 does sound better to me.
maus92
Eastern Shore
It's not your radio and it's not a vocoder / FDMA / TDMA issue then. Sometimes individual dispatchers don't have their headset adjusted properly, a particular console's audio subsystem is misadjusted, etc.
dustinsterk
Thanks. I just looked and it’s frozen again. Was holding on a TG for about an hour before this happened.
I noticed another lockup today with the latest FW. I was messing with the speaker when it happened....probably just a coincidence but I will continue to keep an eye on any pattern.
  • Like
Reactions: btt
btt
Jew lover
Wa State
Do you mean you were messing with a connection on the 3.5mm jack? Or messing with audio/speaker settings in the configuration menu?
K9DAK
Wauconda, IL
Yes, what maus92 said... I have this same issue with our dispatch center. The tone-out and Locution dispatch voice are crystal clear, as are the responding apparatus. The human at the console, however, is mostly always garbled, and I noted this since before I even got a P25RX-II, even on the patch to their analog VHF FM frequency.
btt
Jew lover
Wa State
Sometimes there are problems with the uplink. I have one talk group here for an analog patched system that sounds horrible all the time. It isn't just because it's analog. They are obviously missing lots of frames on the uplink.
btt
Jew lover
Wa State
I finally realized what you are thinking. It is true that if only one of the voice slots is active, it will not result in a change to the occupied channel bandwidth. That is because the symbol rate is a constant 6000 symbols/sec regardless whether there are 1 or 2 slots active. Ultimately, it is this rate combined with the deviation and pulse shaping that determines the occupied bandwidth. It is incorrect however to say that each slot uses the full 12.5 kHz bandwidth, otherwise there would be no room for the other slot and control information. The reason that the vocoder is half rate, is to reduce the required bandwidth by one half. This is what allows two active voice channels into a single 12.5 kHz channel (utilizing TDMA to interleave). I agree that it does sound good despite the bit rate being cut in half!
btt
Jew lover
Wa State
This is a GREAT antenna for the Micro..
700/800MHz Replacement Long Rang SMA Male 7dBi Antenna for HP UNIDEN HP-1 HP-2 Scanners & More HomePatrol 1 2, Slinkdsco
Received the Slinkdsco antenna today. It is a good antenna. Thanks!
dustinsterk
Messing with the actual 3.5mm jack, nothing in the menu. Has not happened since.
  • Like
Reactions: btt
btt
Jew lover
Wa State
8 tone pairs is PLENTY for my apps
There is a new version available. Multiple tone pairs are decoded and displayed per call. The display format is now the index values (1-72) from Figure 2 in the document you referenced earlier for two-tone decoding. The next release will support configuration of up to 16 tone pairs, a tone-match TG timeout, GPIO options, and an alias for tone pairs.
