I tested the application on an Intel-based Mac Air Book. It works flawless for me. Are you using an Intel-based or Apple silicon-based machine?
Another related question. How large is your microp25rx_backup.ini file?
I don't have a way to test the Apple M1 silicon here.Macbook pro - silicon-based M1
I tested a configuration with 10x that size, so that isn't the issue.20KB in size
I think you are saying the <write config> with your backup.ini file cut-and-pasted into the GUI editor works fine. It sounds like everything is working well except for the <read config> operation. Acknowledgement / retries for USB read operation are not currently implemented. It does check for correct length and out-of-squence packets. That wouldn't explain why you are seeing a "lock-up", but I will try adding ack/retry functionality on reads next and see if it helps.Strangely, if I copy and paste the text from my backup and do a restore, it works perfect from the GUI.
Nice work! Can you get it to work with a delay of less than 5000?I found a solution....it maybe just a race condition. I added a sleep for 5 seconds inside a try catch (changes in bold) and now it works perfect:
private void read_configActionPerformed(java.awt.event.ActionEvent evt) {
if(busy!=0) return;
System.out.println("read config");
total_bytes=0;
data_frame_off=0;
ta.setText(""); //clear all text
try{
//send_config causes the receiver to send BACKUP ini config information to port 6
packet_id=0; //increment this on ack for >1 frames
byte[] b = new String("send_config\r\n").getBytes();
send_frame( b, b.length, 0, 1, packet_id); //port 1 is a \n-terminated command string
Thread.sleep(5000);
} catch(Exception e) {
e.printStackTrace();
busy=1;
read_timeout=200;
Try replacing Thread.sleep(x) with parent.port_to=1200; Does that work with the delay?Thanks! 1 second sleep is too short, but 2 seconds seems to work every time for me.....I assume it depends on the total length of the config / bytes from flash memory on the device.
Thanks. I'll look to see if there is a way that I can add the Thread.sleep for the M1 platform only. It may have to be a configuration file or something.Tried it, but it only worked 1 out of 5 times...the other 4 times it froze.
Does the following work ok?
try {
//sleep on Mac M1 platform only
if( System.getProperty("os.arch").toLowerCase().equals("aarch64")) {
Thread.sleep(2000);
Thanks. I committed the change to the github repo. v011001 is available as source.Yes working well......pasting my full code just to make sure it is what you expect:
if(busy!=0) return;
total_bytes=0;
data_frame_off=0;
try {
Thread.sleep(2000);
busy=1;
read_timeout=200;
This is the version of the MicroP25RXMon application. The Mon application currently does not show the firmware version of the hardware, yet.VER 2023010605
