1955 EST- KYLE 11 up on ZQX 133.150 LiveATC1807 local KYLE-11 now on Cape freq..
You can find BURNM in the FAA waypoint Database. Also if you enter BURNM into Skyvector it will center the map on it's location, it's just not charted on any of the maps.Earlier today I tried to add their link for the BURNM waypoint in W-107, but it is not listed.
I also like this site: Aviation Charts on Google Maps | iFlightPlannerYou can find BURNM in the FAA waypoint Database. Also if you enter BURNM into Skyvector it will center the map on it's location, it's just not charted on any of the maps.
Thanks.... With that site I was able to pull up DCA for a better outline of where the new limits on helicopter flights are. With enough detail to get some ideas.I also like this site: Aviation Charts on Google Maps | iFlightPlanner
Yes, I've caught OMEGA on the BURNER track with NIGHTMARE 11 on 227.525 and LUCKY flt with BACKY on 283.75The Burner ATCAA overlies a portion of Cherry Point’s airspace from FL180 to and including FL230. The upper altitude may be increased to FL290 through coordination with Washington Center.
I've heard them use 266.400, 310.100, 364.350 in there. Anyone know of anymore ?
They were pining on INMARSAT and The Bald Geek has his map back up and I could see them there before they turned ADSB back on southbound RTB. ACARS HubJust had a FLAM-11 flight on Cape freq.. Figure if heading up to AR-20 should pass the Cape perhaps.
1807 local KYLE-11 now on Cape freq.. Boston center welcome.
McGuire KC-46's getting slick leaving ADSB mode off on these trips
262.950 - WIZARD (most likely the P-8) with Echo Control on discrete as posted earlierA Jacksonville P-8A operating in Pax River area on Pax discrete 262.450.
Someone says one more lap then done.Guess unid chase plane.
AR with SHREW 22PIRAT25 AE3074 57-1508 K35R heading south over Raleigh doing refueling with unidentified on 324.6
Great find, thank you.AR with SHREW 22
I just reviewed the "tape" and the callsign was WIZARD-15 on 305.200 - BAYWATCH. From there they switched to 262.950262.950 - WIZARD (most likely the P-8) with Echo Control on discrete as posted earlier
ATCAA. If you select the "Air Traffic Control Assigned Airspaces" box on the SUA website in the "Map Layers" tab (to the right) it will show up. It's not a default so you have to check it manually. FAA SUA Website The BURNER ATCAA shows active today from 1600 EST to 1745 EST and again from...forums.radioreference.com
I got it I needed a rebootI can't seem to get that link to work or open the site opennav.com any ideas? VPN maybe?
LiveATC Burner AR Frequencies has a radio dedicated to Burner AR frequencies but for a week now it seems to have a loud Birdie like it is stuck on one of the frequencies and is inoperable. Does anyone know who is feeding that stream and maybe they can fix it?Yes, I've caught OMEGA on the BURNER track with NIGHTMARE 11 on 227.525 and LUCKY flt with BACKY on 283.75
