jsoergel
Cincinnati/Dayton, OH
1015- Unid acft (no call noted-self id as single F-18) w/Potomac (269.625)>ZDC Lexington (281.4). Maybe a VX-23 acft heading somewhere?
1030- Looks like of the Clean KC-135s (#61-0314) is off DOV heading west. Yep, on Potomac (124.55) as Clean 33 flt. Then w/ZDC Baltimore (134.5) cleared in block FL130-140. At 1040 cleared to block FL200-230. Also w/ZDC Leesburg (133.975) heading west in block FL250-260.
CLEAN 33/34 (60-0314/58-0113) w/TABOR 81 (x6)
236.750 boom
228.100 tac
CLEAN 43 (61-0280) w/TABOR 91 (x4)
293.000 boom
377.300 tac
nodak1crdet3
Detroit, MI
Slightly off topic, but this weekend was monitoring fisherman using FLTSATCOM freqs, not unusual. However, at the moment I have what sounds like a rebroadcast of a religious music and a prayer on 261.835MHz FM-N. Maybe someone else picking that up?
No joy here in Detroit. I tried FM, & NFM @ 01:35pm.
Chuck in Detroit
mdmonitor
1035- AF2 (C-32 # 98-0001) off ADW heading northeast.
1055- Couple of acft on 246.9. No idea who or where they are. Sounds like same guys on ZDC Buena Vista (319.0).
1057- Decoy 99 (C-17 WVA ANG) trying to Contact Pitt 58 (KC-135 PA ANG) on 274.45 (AR218)
1105- Couple of NJ ANG F-16s on 298.6. Mention Wash Center on 126.875.
mdmonitor
1110- Steel 71 (KC-135 # 58-0077 PA ANG) w/Steel Control (311.0). Inbound msg w/status code 1. Will do patterns for 30 mins prior to landing.
1115- Hades 11 (NJ ANG F-16) w/ZDC Sea Isle (285.4).
1120- Jumbo 71 (C-5M 9th AS DOV) w/Kiowa Range (233.45)
1138- Titus 26 (C-12 DEFENSE SECURITY COOPERATION AGENCY ADW) w/Potomac (128.0) requesting entry in R4006. Then advises they will head to Salisbury MD then head out to the test Track off MD/DE coast.
john8436
Philadelphia, PA
Yesterday I was just going over the ADSb Exchange map to see what aircraft were in flight. One of my stops is to look at Boeing Field.
It appears the first prototype of the US Air Force E-7A Wedgetail airframe was conducting it's 2nd test flight. Interesting considering the budget cuts. The following is the aircraft information that I was able to collect.
2025 Boeing 737-700, US Air Force, N471DS, A5C52D
Yeah odd situation. the Pentagon says they can do fine without them and stick with E-2D's but many Congress folks and lobbyists
say the E-7 is a must.. See who wins out in the end.. My money is on the Congress/Lobbyists :)
mdmonitor
1027- Hearing couple of acft on 298.6. No calls noted
1028- Terra 58 (C-32 NJ ANG) w/Steel 62 (KC-135 PA ANG) on 274.45. Advises Steel 62 they have having equipment issue and have to RTB. Were going into AR218. At 1030 Terra advises they have cleared up issue and are proceeding to the IP.
1035- Venus 02 (VC-25 # 92-9000) patterns at ADW (125.65/118.4) after a short flight around the local area.
