Mid-Atlantic MilAir 2023
TerryPavlick
Wallingford PA Villas NJ
NASA806 U2 Active. Probably one of the furthest hits I have had, but helps with them at FL600
Yeah the altitude really helps. It was tracking northeast of me (where all the trees and buildings are on the horizon) so getting 245 nm out of it was great that direction. On good days I can "see" aircraft over east central Ohio - which is in the 270 -300 nm range. It helps the horizon that way is water and more water.
Tank67
New York
1245 and that U2 is tantalizingly close. If this region wasn't under thick cloud cover I'd invest an hour or so driving west to try to snag a shot. Hopefully an opportunity will present itself down the road... View attachment 134811
Having the same problem, it'd be nice if a cold front came through and got rid of these clouds that have been loitering for weeks and weeks now
mdmonitor
1420- Venus 01 (VC-25 # 82-8000) working pattern at ADW. Seems a fair amount of non-POTUS work for this old airframe recently. Getting worn out & needing more maintenance or new crew and need more evaluation?
1422- Tester 15 (T-38C # 610925 NTPS) working Bay Watch (354.8) reporting speed run at Mach 1.08 at FL350.
Lot of DEED tankers off and running Eastbound.
DEED-25 18-46049 22ARW
DEED-26 15-46009 22ARW
DEED-12 #63-8013 Ohio ANG
DEED-14 #61-0317 AZ ANG. mispelled DEID.
Couple of MacDill KC-135's enroute Rio Brazil SBGL. Long haul for them.
KNIGHT-01 #57-1403
BOLT-01 #63-8879
