Mid-Atlantic MilAir 2023
KO4RJX
Benson, NC
Yeah the altitude really helps. It was tracking northeast of me (where all the trees and buildings are on the horizon) so getting 245 nm out of it was great that direction. On good days I can "see" aircraft over east central Ohio - which is in the 270 -300 nm range. It helps the horizon that way is water and more water.
I might have the ability to put an ADS-B receiver around the 300 foot mark of a tower down the road. Wonder what the range would be at that height? :ROFLMAO:
Lot of DEED tankers off and running Eastbound.
DEED-25 18-46049 22ARW
DEED-26 15-46009 22ARW
DEED-12 #63-8013 Ohio ANG
DEED-14 #61-0317 AZ ANG. mispelled DEID.
DEED-13 #59=1509 EB
DEED-22 #18-46039 22ARW
DEED-23 #62-3506 Iowa ANG
DEED-27 #18-46054 Pease.
Seems the KC-46's are all headed to LERT Rota Spain.
Thinking the KC-10's May be DEED-11,21 down the road on this move.
Someone on twitter said 5th Bomb Wg Minot mission codes for these tankers.
A Vid just up of that Nuke sniffer MILLER-36 that was working out of San Juan..
Almost looks like APU's mounted on the sides but guess could be air sample collectors?
Up on front of tail fin looks like another gadget that looks like a microphone.. Maybe that is sampler?
Also a rare Boeing B-727-200 VP-BAP which seems to have a home in Van Nuys Cal.
Seems like yesterday 727's were a dime a dozen.
4K- PLANE SPOTTING 2023 SanJuan The New Constant Phoenix WC-135R & Private B727-100. - YouTube
Report the DEED tankers are for this exercise Joint Oak-23 going on in Israel. Does list B-52 strategic bombers under Centcom release.
Eight tankers with 4 on this side suggest at least 4 or more Buffs perhaps.
CENTCOM and Israel Defense Forces Conduct Exercise Juniper Oak 23.2 > U.S. Central Command > Press Release View
dmi
Somewhere In, MD
I was curious so I did some calculations. It's actually not a big factor unless the aircraft is at low altitude with obstructions in the way. The calculation I used didn't take into account RF propagation, obstacles, transmission line loss, antenna gain. It just uses the height of each antenna.
An antenna at 300 feet will receive an aircraft at an altitude of 30,000 feet from a distance of 269 miles (approx. 234 nm)
With an antenna at 10 feet same altitude for aircraft distance = 249 mi (approx. 216nm)
That's a difference in distance of 20 miles!
When you get up to the frequencies that ADS-B uses, propagation comes into play much more so than VHF/UHF.
ADS-B Frequencies
  • Mode-S Extended Squitter: 1090 MHz;
  • UAT: 978 MHz.
  • Interrogator: 1030 MHz.
For those that are interested.... I used this site:
TerryPavlick
Wallingford PA Villas NJ
ADS-B Frequencies
  • UAT: 978 MHz.
Just curious - are you surprised that it is only a 20 mile increase ?
KO4RJX
Benson, NC
More than I thought actually. One day I'll run out to the tower, hook up a receiver and see what it gets.
U.S. Air Force Airmen from the 104th Fighter Squadron and various units from the 175th Wing, Maryland Air National Guard, arrive at the Air Dominance Center, a Combat Readiness Training Center, on Jan. 19, 2023, to participate in exercise Sunshine Rescue which will take place through Jan. 28, 2023 in Savannah, Georgia.
Tank67
New York
Madfox
Brummy Land, United Kingdom
Complete log for the SP to Kadena, went on a bit this one!
Coronet West 411/22-23
08/01/2023
RUMMY64/62-3500/KPHX>KWRI
09/01/2023
RUMMY61/79-1711/KWRI>EGUN
RUMMY71/84-0186/KWRI>EGUN
Andrews 11/01/2023 CW411 Westbound
JEST 11-16 ETAD>KADW
90-0828 F-16C 480FS/52FW/SP
91-0338 F-16C 480FS/52FW/SP
91-0342 F-16C 480FS/52FW/SP
91-0361 F-16C 480FS/52FW/SP
91-0416 F-16C 480FS/52FW/SP
96-0080 F-16C 480FS/52FW/SP "480FS"
79-1711 KC-10A 305AMW/McGuire RUMMY61 EGUN>KPSM
58-0100 KC-135R 351ARS/100ARW/D RUMMY62 EGUN>EGUN
62-3500 KC-135R 197ARS/161ARW/AZ`ANG RUMMY64 KWRI>KWRI
JEST 21-26 ETAD>KADW
90-0813 F-16C 480FS/52FW/SP
90-0829 F-16C 480FS/52FW/SP "52OG"
91-0417 F-16C 480FS/52FW/SP
91-0418 F-16C 480FS/52FW/SP
92-3918 F-16C 480FS/52FW/SP
96-0083 F-16C 480FS/52FW/SP
84-0186 KC-10A 305AMW/McGuire RUMMY71 EGUN>KPSM
57-2605 KC-135R 351ARS/100ARW/D RUMMY72 EGUN>EGUN
16-46021 KC-46A 305AMW/McGuire RUMMY74 KWRI>KWRI
12/01/2023
RUMMY61/84-0186/KPSM>PAED
RUMMY64/62-3500 KWRI>KWRI
JEST11-16 KADW>PAED (serial order unconfirmed)
13/01/2023
RUMMY71/79-1711/KPSM>PAED
RUMMY74/16-46021/KWRI>KWRI
JEST 21-26 KADW>PAED (serial order unconfirmed)
14/01/2023
RUMMY81/86-0031/KSUU>PAED
Kadena 16/01/2023 CW411 Westbound
JEST 11-14 PAED>RODN
84-0186 KC-10A 305AMW/McGuire RUMMY61 PAED>RJTY
62-3559 KC-135R 909ARS/18Wg/ZZ RUMMY63 RODN>RODN
JEST 21-24 PAED>RODN
86-0031 KC-10A 60AMW/Travis RUMMY71 PAED>RJTY
58-0086 KC-135T 909ARS/18Wg/ZZ RUMMY73 RODN>RODN
17/01/2023
RUMMY61/84-0186/RJTY>KSUU
RUMMY71/86-0031/RJTY>PAED
18/01/2023
RUMMY61/84-0186/KSUU>KWRI
RCH025/79-1711/PAED>KWRI
Kadena 19/01/2023 CW411 Westbound
JEST 31-32 PAED>RODN
86-0031 KC-10A 60AMW/Travis RUMMY81 PAED>RJTY
62-3559 KC-135R 909ARS/18Wg/ZZ RUMMY83 RODN>RODN
20/01/2023
RUMMY81/86-0031/RJTY>KSUU
22/01/2023
RUMMY81/86-0029/KSUU>PAED
Yokota 24/01/2023 CW411 Westbound
JEST 33-34 PAED>RJTY (divert)
86-0029 KC-10A 60AMW/Travis RUMMY91 PAED>RJTY
