Mil Air
bearcatrp
Land of 10,000 taxes
Who in central Minnesota are picking up any Mil Air? You folks around twin cities, duluth, and around camp riply probably pick up something. Am debating on a Omni X but my past scans are pretty much dead. Not sure I want to invest into a dedicated antenna if there are very low radio transmissions in my area.
aprswatcher
Lewistown, Montana
I have the DPD Omni X antenna for mil-air, it is a great antenna, very well built and not really large. It does a great job on the aviation frequencies and just as well on the vhf public service frequencies.
Hopefully this will get you some mil-air activity and maybe others will post some more frequencies and info.
There is an Air Refueling (AR) tracks that runs East-West from Minnesota to Wisconsin. AR 109 H (high) and AR 109 L (low).
AR 109H is altitudes between 25,000-31,000 feet, primary frequency is 343.5 am, secondary 320.9 am.
AR 109L is altitudes between 19,000-23,000 feet, primary frequency is 327.6 am, secondary 320.9 am.
AR 453 in N. Dakota frequency is 291.9
A couple of MOA’s (military operating area) in N. Dakota:
606 frequency of 366.3
619 frequency of 238.9
629 frequency of 296.0
You will hear bombers, fighters and cargo aircraft refueling in the AR tracks.
Try these frequencies for the Air National Guard out of Duluth. 139.9 and 288.9.
Minneapolis/St. Paul has 2 C-130 units:
The Air Force Reserve uses the callsign “Viking xx” and listen for them on 282.675
The Minnesota Air National Guard uses the callsign “Gofer xx” listen for them on 324.1
Also input frequencies 311.0 and 321.0 these a common frequencies for command post around the US, most use callsign
“Raymond xx”
You should also hear some of the B-52’s out of Minot using air to air frequencies of 300.125 and 300.225, most common callsign I
hear is “Chill xx” and they have numerous others.
Good luck and let us know what you hear!
73, Rex
bearcatrp
Great info. thanks for your reply. How High is your omni x antenna? I should be able to get it about 25 feet in the air if I get one. Will be above the roof line like my discone is.
aprswatcher
Lewistown, Montana
It’s at about 40’ in a tall ponderosa pine!
Add these frequencies also for AR 607 in Wisconsin:
235.1, 364.2
73, Rex
aprswatcher
Lewistown, Montana
It’s just over 100’ run of LMR-400. It goes to a Stridesburg 4 port multicoupler.
Antenna works great for what I monitor.
73, Rex
kylemac
Southern Minnesota
I live in central southern Minnesota, about 10 miles from the Iowa border. That said, I have a discone antenna about 25 or so feet in the air, allowing me to easily pick up training flights in Iowa's military flight zone.
It's not the best area for military flights, but usually I get air-to-air communications among military pilots regarding their off-duty plans.
bearcatrp
I seemed to be in a dead zone in regards to mil air. Scanned today with no hits. Did catch some data transmissions. Going to order a mil version of the Omni X next month. Hoping this will help.
kylemac
Southern Minnesota
Actually, you might well be in a hot spot. Lots of aircraft heading into the area on their way to Minneapolis International. Some of them are bound to be military aircraft passing through...
That said, I have an older Uniden BC780XLT connected to my pc. It has loads of channel space easily accessed via USB with Proscan. I think you just need to search out some known frequencies and see who comes to visit your area.
nodak1crdet3
Detroit, MI
Give these a try for Duluth MN F-16's.
I haven't been out there in about 20 years, but these freqs were active back then.
Chuck in Detroit / NODAK 1
BruceMN
Duluth, Minnesota
Most of those frequencies are not currently active. I live in Duluth but have not had time to search for their new frequencies. The base frequency is still active: Bulldog ops on 139.9.
